Polyurethane Not Cureing - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-04-2009, 12:25 AM   #1
Rewards Points: 119
Polyurethane not cureing
I have touched up the wood cabinetry in my bathroom consisting of framed mirrors and have applied polyurethane. I have used it before with good success. But this time it has dried on the surfaces and on the upper sides of the trim surrounding the mirrors but not on the sides at the bottom. Here it is still tacky after 3 days. Can anyone tell me why.
debd is offline   Reply With Quote
Old 12-04-2009, 07:01 AM   #2
There is something in the underlying finish or surface that reacted with the poly. Give it some more time, if it does not cure, you will have to strip it and start over.
Old 12-04-2009, 09:14 AM   #3
Agree. Sounds like there may be wax on it. Try wiping it down with a mineral spirits dampened rag to wipe off the residue.
pinwheel45 is offline   Reply With Quote
Old 12-04-2009, 10:16 AM   #4
the Musigician
DangerMouse's Avatar
in the bath, it could likely be soapscum or cleaner residue as well as possibly wax.
always thoroughly clean any surface to be painted. scuff sand if needed, primer and paint.
DM
Old 12-04-2009, 12:40 PM   #5
Rewards Points: 119
Thanks for all the info. I'll see what I can do with it now.
Old 12-05-2009, 07:34 AM   #6
DIY staff
Rewards Points: 7,174
Poly will lift lacquer-I don't know if this is your situation--If some hardened but not all-I agree with the others--Probably the surface was contaminated with crud.-MIKE-
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 11:50 AM
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 09:42 AM
oil vs water poly batwoman Flooring 6 09-30-2008 11:00 PM
Minwax Polyurethane vs. Minwax Polyurethane Floors proofer Flooring 3 04-06-2008 09:48 AM
Staining Wood Floor -- Use Polyurethane or FLOOR Polyurethane? proofer Painting 2 04-05-2008 08:47 PM
