Polymer Coated Bar Top - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-21-2011, 12:07 AM   #1
Polymer coated bar top
I am pouring a polymer bar top which I have done before and have it pretty well down. This time I am putting a arm rail (5-1/4" cherry) around the bar on top of the polymer after it is cured. My question is will a 18 ga. brad nail go through the polymer and will it not damage the polymer?
Hort is offline   Reply With Quote
Old 06-21-2011, 06:10 AM   #2
DIY staff
Rewards Points: 7,174
The nails or brads will shatter the finish---sooner or later---
Install the bar rail first or add a nailing strip to the edge that is as thick as your pour and wide enough to support the bar rail.---Mike---
Old 06-21-2011, 09:50 PM   #3
What about screwing up through the bottom of the bar top into the rail? (obviously using appropriate length screws as not to pierce the surface of the rail)
SoCalLivin is offline   Reply With Quote
Coated vs uncoated lawn seed jrepp44 Landscaping & Lawn Care 2 10-21-2013 12:04 PM
stone coated steel and spray foam insulation waternut Roofing/Siding 2 01-15-2011 06:36 PM
Skim Coated Walls question SPB Painting 8 01-18-2010 04:41 AM
What primer for a skim coated wall slickracer Painting 6 12-16-2009 03:58 AM
regular zinc coated steel hardware with ACQ treated lumber dumbunusedid Building & Construction 3 08-12-2008 07:20 PM
