Pocket Entry Door - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-12-2011, 08:38 PM   #1
pocket entry door
i have a small living room and the front door opens into it blocking the couch i was thinking of fabricating a pocket entry door. or is there one on the market already? cant seem to find one.
kelleyw is offline   Reply With Quote
Old 08-12-2011, 09:50 PM   #2
Rewards Points: 558
Pocket door systems are offered either as kits or as pre-assembled units. The pre-assembled types, sold through lumberyards and home improvement centers, include a jamb, hanger track, and pre-made cage that, when finished, becomes the pocket.
epson is offline   Reply With Quote
The Following User Says Thank You to epson For This Useful Post:
kelleyw (08-13-2011)
Old 08-12-2011, 11:38 PM   #3
Rewards Points: 5,336
I've never seen an exterior pocket door.
Ron
B. Franklin 1759
Old 08-13-2011, 01:10 AM   #4
jschaben
Rewards Points: 502
Question
I don't know if codes would allow pocket doors for egress. I could foresee problems in emergency situations.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 08-13-2011, 01:56 AM   #5
Remodeler
Rewards Points: 300
Sliding patio door
iamrfixit is online now   Reply With Quote
Old 08-13-2011, 06:21 AM   #6
KemoSabe
loneframer's Avatar
A true pocket door is going to allow very little in the way of insulation options, which is one reason you don't see them in homes.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 08-13-2011, 07:05 AM   #7
jschaben
Rewards Points: 502
Originally Posted by iamrfixit View Post
Sliding patio door
Difference being sliding patio doors are totally exposed, pocket doors are totally enclosed. I dunno, just askin?
John Schaben
Old 08-13-2011, 07:35 AM   #8
DIY staff
Rewards Points: 7,174
Consider buying a front door that swings out.
Old 08-13-2011, 02:00 PM   #9
Remodeler
Rewards Points: 300
Yes, the door would be exposed, but it's the closest thing you are going to find to a pocket door for an exterior wall.
Old 08-13-2011, 02:02 PM   #10
bubbler's Avatar
Rewards Points: 256
Also may be against code in some places because the door can be blocked and prevented from opening (mostly an issue with snow).
bubbler is offline   Reply With Quote
Old 08-13-2011, 02:04 PM   #11
bubbler's Avatar
Rewards Points: 256
Would switch the door from LH to RH help at all? I'm guessing you've explored changing the furniture or it's arrangement too right? that would be much easier
Old 08-13-2011, 02:45 PM   #12
Registered User
Rewards Points: 4,924
“R311.2 Egress door. At least one egress door shall be provided for each dwelling unit. The egress door shall be side-hinged, and shall provide a minimum clear width of 32 inches (813 mm) when measured between the face of the door and the stop, with the door open 90 degrees (1.57 rad). The minimum clear height of the door opening shall not be less than 78 inches (1981 mm) in height measured from the top of the threshold to the bottom of the stop. Other doors shall not be required to comply with these minimum dimensions. Egress doors shall be readily openable from inside the dwelling without the use of a key or special knowledge or effort.” http://publicecodes.citation.com/ico...011_par001.htm
If you substitute another door in a different location, it needs to meet egress path code: “R311.1 Means of egress. All dwellings shall be provided with a means of egress as provided in this section. The means of egress shall provide a continuous and unobstructed path of vertical and horizontal egress travel from all portions of the dwelling to the exterior of the dwelling at the required egress door without requiring travel through a garage.”—check out floors and landings at egress doors, also; http://publicecodes.citation.com/ico...9_3_sec011.htm
Gary
The Following User Says Thank You to Gary in WA For This Useful Post:
Old 08-13-2011, 03:03 PM   #13
DIY staff
No code issues anywhere in the U.S. or Canada--All commercial buildings require outswing doors.
Old 08-13-2011, 04:39 PM   #14
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Yes but are they intended for use as exterior doors?
I don't think so!
Kelleyw, are there any electrical devices (inside or out) that would interfere with this notion? [ie. Light switches, porch lights, door bells, etc.]
XXX
Old 08-13-2011, 05:36 PM   #15
Rewards Points: 558
I don't think so!
Your right Bud, I was reading and posting at the same time and caught it after I posted. And no they donít make them for exterior doors.
Installing an Entry Door heathmac Carpentry 14 11-10-2010 09:06 PM
Entry Door installation... Advice needed! mburgess44 General DIY Discussions 19 09-12-2009 08:46 PM
Pocket door - Need hardware HELP Gawthorne Carpentry 3 03-08-2009 10:55 AM
pocket door help cmnelson74 Remodeling 1 03-06-2009 03:19 PM
