Pocket Doors Driving Me Nuts - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-08-2013, 08:47 AM   #1
Rewards Points: 2,072
pocket doors driving me nuts
I love the looks of these double pocket doors, (off the living room), but most of the time when I close them there's a gap (photo #1). I grab them on each side and shake them and then they close tightly, (photo #2).
Seems like I'm pulling them out too far, but I have no way of knowing in advance. Is there something I could do to put a block on them so they aren't opened too far which creates the gap?
thank you
Startingover is offline   Reply With Quote
Old 05-08-2013, 09:07 AM   #2
Haverhill Trade 1965
pocket door adjustment
It sounds like the rollers or track hardware are worn or loose. If they don't stop in the center then the two stops are missing or loose. there should be two aluminum clamps with rubber bumpers and a locking screw in the track an inch or two from the center to stop the doors. Loosen the screw move it toward the door an re tighten. It may take a couple tries to get them exact. If the rollers or track are loose half of one roller may have jumped out of the track until you shake them. Look to see if there are screws holding some of the trim on. there should be because you have to remove some of it to adjust or repair the track or rollers. Hopefully the hardware installed was not for lighter doors. Let us know how you make out.
Duckweather is offline   Reply With Quote
The Following 3 Users Say Thank You to Duckweather For This Useful Post:
BigJim (05-08-2013), jagans (05-08-2013), Startingover (05-08-2013)
Old 05-08-2013, 11:01 AM   #3
Roofmaster
Rewards Points: 2,172
In Photo 1 it appears that the gap is mush wider at the top than the bottom. Maybe a roller is riding up on a fastener that has backed out? Also, what about drilling with a forstner bit and installing a round magnet and a plate flush with the edge on the top and bottom?
The Following User Says Thank You to jagans For This Useful Post:
Old 05-08-2013, 11:22 AM   #4
jagans,
You're talking to a semi-handy Irish female (who derives great satisfaction from fixing things myself) and I refuse at this point to hire anyone, but I don't understand your last sentence.
Where would I get a 'round magnet' to drill and where do I get a 'plate' ?
thanks
Old 05-09-2013, 02:53 AM   #5
If installed correctly some of the trim should be held on by screws but may be filled to hide them. the filled holes for a screw would be larger than the finish nail holes. If you can find them, one of the narrow top side frame pieces should be removable. Look up into the space the door travels in and you will see the track shaped like a J. The rollers, one pair near each end of the door ride in the J. It should be the piece on the open side of the J that you want to remove. The top casing may be fastened to it, if with nails and not with screws you may have to pry the casing away and cut the nails with a hacksaw blade. If you remove the frame piece you will see what is causing the problem. You can Google, Johnson or Stanley pocket door hardware you can see what all the parts look like. It uses two sets for a double door like yours.
The Following User Says Thank You to Duckweather For This Useful Post:
Startingover (05-09-2013)
Old 05-09-2013, 02:04 PM   #6
Rewards Points: 1,442
Because the gap is wider at the top than at the bottom, at least one of the door panels is mistracking. You might open both doors and then slowly slide them closed one at a time to see which door is going astray and why.
Old 05-09-2013, 10:38 PM   #7
Roofmaster
Originally Posted by Startingover View Post
jagans,
thanks
Well why didn't you say so? Just whack it with your shillelagh till it closes.
You can buy those round puck type magnets at HD in the hardware section, and just buy a metal strap there too. Same Isle. Epoxy the magnets in a recessed hole that you drill in the edge of the door.
It looks like you have a loose track or fastener though. I have faith in you now that I know your Lineage, but you might need a carpenter like yours truly to really fix it right.
Old 05-09-2013, 11:19 PM   #8
That's what I like about this site. For all the hard work everyone does, there's always time for a smile.
Adjust pocket doors Italgrl Carpentry 13 01-15-2013 10:13 PM
pocket doors ...how to make fire rated clasact Building & Construction 21 03-11-2011 05:46 PM
dual-switch light driving me nuts prj Electrical 17 02-20-2010 09:57 PM
Bifold doors driving me crazy! Gevans17 Carpentry 8 01-29-2009 05:12 PM
Picking a color is driving me nuts...please help me! melissaandkris Interior Decorating 7 06-25-2008 01:30 PM
