Pocket Doors... - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-07-2007, 12:26 AM   #1
Rewards Points: 150
Pocket Doors...
This may not be the right section, but I am wondering if anyone know if you can remove the door from one of those pre-hung pocket doors?
I've never had any success in any remodels in the past and have just removed them completely. But in this case, I'm just putting in flooring and the door needs to be shortened at the bottom and didn't think it would be a good idea to cut it while it's still hanging...
slakker is offline   Reply With Quote
Old 09-07-2007, 12:43 AM   #2
Cabinet Installer
Dansbell's Avatar
There should be some flat trim that is on the inside of the jamb. you should be able to pop that loose. With the door in the open position look under it. There will be a guide at the floor that will need to be removed. Once you have those removed you should be able to open the door and swing the bottom back and forth. Swing the bottom out and you will then just lift it off the track.
Good Luck
Daniel S. Bell
Belbuilt, LLC
Cabinet Installation Medford, Oregon
http://www.belbuilt.com
Dansbell is offline   Reply With Quote
Old 09-07-2007, 07:42 AM   #3
zel
Rewards Points: 150
Send a message via AIM to zel
If it is a Johnson pocket door kit, you should be able to remove a top section of jamb with 3 screws, then you can lift on the door and slide the trolleys out of the slotted hole in the top of the door brackets.
zel is offline   Reply With Quote
Old 09-07-2007, 11:36 AM   #4
Rewards Points: 150
thanks for the tips... I'll give it a try...
non pocket sliding doors? jamesdart Remodeling 3 03-07-2009 05:48 PM
Home Made Closet Doors allen1466 Building & Construction 9 10-25-2007 05:57 PM
Attic Doors cyepsen Building & Construction 3 06-24-2007 07:47 AM
Pocket doors ? burita General DIY Discussions 2 01-08-2006 10:38 PM
Pocket Doors wicklowdesigns@yahoo.com Building & Construction 2 07-06-2005 08:21 AM
