Pocket Door Framing And Installation - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-24-2008, 02:37 PM   #1
Rewards Points: 60
Pocket Door Framing and installation
I am remoldeling my bathroom. It previously had a pocket door, but the framing and everything around it were badly damaged by termites. I removed all of the damaged framing, but now I find myself lost in how to frame the opening and how to install it. I bought a reliabilt pocket door kit from the local home improvement center, but obviously there were no directions. I need to know the rough opening and any other dimensions that will help with my installation. HELP!!!!
res17nn9 is offline   Reply With Quote
Old 10-24-2008, 02:42 PM   #2
the Musigician
DangerMouse's Avatar
http://www.johnsonhardware.com/pdindex.htm for how to videos
i love my pocket doors, though i only use Johnson hardware. =o)
DM
Old 11-03-2008, 07:39 PM   #3
remodeling pro
DM
Not familiar with the quality of the hardware for that brand, but just knowing that it is big box makes me suspicious. I don't use anything but Johnson also. If your kit does not have quality nylon wheeled trolleys and a decent thickness track, you will be unhappy down the road. Attention to detail is essential for long term success. The track must be absolutely level and well supported, and the studs, especially the end ones that will receive the jamb trim, must me pefectly plumb. Install the door(s) and adjust them before you enclose the pocket with drywall.
troubleseeker is offline   Reply With Quote
Old 11-03-2008, 09:26 PM   #4
Custom Cabinet Maker
DaMouse got it right!!!!! clear the floor, put the whole thing together temporarily, measure the unit, then ya gots the RO for it. Only way if you dont have destructions. Could try their website. To me faster just to pop it together "dry" get ur numbers and git er done
skymaster is offline   Reply With Quote
Old 11-04-2008, 04:42 AM   #5
the Musigician
ACTually.... they sell Johnson track kits at Lowes, but they are the lesser grade wheels, and i only saw one size.
and of course i'm right!
DM
Electricl Installation for Electric Tankless Water Heater Educator Electrical 13 07-06-2008 10:27 AM
SubStandard Roofing Installation Fred213 Roofing/Siding 11 05-06-2008 12:15 AM
Pocket Door Installation Randell Tarin Building & Construction 10 03-30-2008 05:30 PM
How to remove interior sliding (pocket) door Horst Remodeling 7 12-13-2007 12:13 AM
Aluminum Soffit and Fascia Installation... MoparAutoworks Building & Construction 1 12-17-2006 07:46 AM
