Pocket Door In An Existing 2x3 Wall - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-08-2010, 08:30 PM   #1
Rewards Points: 83
Pocket Door in an Existing 2x3 Wall
I want to install a pocket door for a small basement bathroom that is currently framed with 2x3s instead of 2x4s. What would be the procedure for creating the rough opening for the pocket door? Rip down the whole 2x3 wall for the pocket door and start over with 2x4s, or some other method?
MrBill_DIY is offline   Reply With Quote
Old 09-08-2010, 08:43 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
A pocket door frame is the same width as a 2X4 so the frame will be too wide to go into 2X3s. If your wall isn't to long you can furr it out and make it work that way instead of ripping it all out.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Willie T (09-08-2010)
Old 09-09-2010, 12:43 AM   #3
Rewards Points: 1,016
To install the pocket door you are probably opening up the better part of a bathroom wall - might be nearly as easy to completely rebuild it properly. A better end result.
The Following User Says Thank You to vsheetz For This Useful Post:
Jay123 (09-18-2010)
Old 09-12-2010, 11:35 AM   #4
Rewards Points: 83
Yes, I expect to be using a kit.
Old 09-12-2010, 07:22 PM   #5
like they said above, they're made for 2X4 walls but we did cheat once and ripped down the kit header and used 1/2" plywood that we glued 1/4" luon to. It worked but like I said, we cheated and had to get creative for the door latch.
II Weeks is offline   Reply With Quote
Old 09-17-2010, 12:58 PM   #6
Rewards Points: 3,130
Aah yes, pocket doors. My wife and I built our log home ourselves, and every single interior door is a pocket door. Not hard to do, but the kits I got from Lowe's (or Home Depot - don't recall) had very poorly written instructions. The first door took me over 2 hours, while the rest were less than 30 minutes.
Old 09-18-2010, 10:46 AM   #7
Johnson is the way to go - IMHO
http://johnsonhardware.com/pdindex.htm
It may look a bit intimidating at first, but when you get into it makes sence and is realatively easy. Just ensure your framed opening is sized correctly and square/plumb.
Old 09-18-2010, 12:15 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 186
One more thing that would seem obvious but some over look is the length of your nails or screws, you don't want to nail your door open or closed.
Jim
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
How to place a new wall in a continuous mathematical alignment with existing wall Frye Building & Construction 9 03-31-2010 10:11 PM
pocket door in load bearing wall aleciadooley Remodeling 15 03-08-2010 07:05 AM
securring an existing railroad tie retaining wall secondguesser Landscaping & Lawn Care 1 07-02-2009 09:52 PM
corner bead on existing wall stallinc Building & Construction 12 01-30-2008 08:38 AM
