Pocket Door Cat Hole - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-04-2012, 03:32 PM   #1
pocket door cat hole
I have a pocket access door to my laundry room. I want to put a cat door/hole in it to give out cat access to the cat box when the door is shut. Any ideas? We need a super thin frame since the pocket in the wall only hive a total of maybe 1/2 inch.
prrchrt is offline   Reply With Quote
Old 07-04-2012, 04:02 PM   #2
Rewards Points: 2,210
Cut rectangular hole in door, reinforce edges where cut, Put flap of plastic on metal bar with pins into both sides for pivot, cover edges with thin aluminum angle or plastic moulding
mae-ling is offline   Reply With Quote
Old 07-05-2012, 04:21 PM   #3
Rewards Points: 150
There are many commercial pet doors that protrude less than 1/8 of an inch on each side. Unfortunately it is not a dimension usually included in Internet descriptions. I would stick with plastic. Aluminum parts can easily gouge the pocket if not careful. Another option is to get the pet doors designed to be mounted in a wall, if you have the space.
goosebarry is offline   Reply With Quote
Old 07-05-2012, 08:48 PM   #4
Too Short? Cut it Again!
This a solid door or hollow cardboard filled one? I would definitely see what stock pet doors are available. Otherwise, a circle saw, pvc bushing and some sort of retaining rings/flanges on either side might be worth looking into. You could make a cute cutout through the wall, and not the door so you have more than 1/2" to work with. Easier to repair the wall than a door when it is time to sell the house too!
Old 07-05-2012, 09:00 PM   #5
the Musigician
DangerMouse's Avatar
I made mine in a hollow door using a saber saw to cut the hole and gluing in a ring I made from 6" PVC DWV.
Then I made decorative rings from 1/4" birch plywood, round insides and octagon outsides, and stained and glued them on both sides.
The cat loves it and the dog hates it.
DM
The Following User Says Thank You to DangerMouse For This Useful Post:
mae-ling (07-07-2012)
Old 07-05-2012, 09:15 PM   #6
From "The Cat's House", a fave book.
The Following 2 Users Say Thank You to user1007 For This Useful Post:
mae-ling (07-07-2012), oh'mike (07-05-2012)
Old 07-07-2012, 02:26 PM   #7
Retired Cabinetmaker
woody4249's Avatar
Rewards Points: 156
Why bother with a cat door with a flap. Trust me....the cat won't care.
Just cut a hole in the pocket door.
I would rough cut the opening slightly smaller than required, then install trim
spacers between the door skins making sure they are square to the door and recessed by say 1/2". Then take a trim router and trim off the excess to get rid of the chipped edges in the door skin created by your jigsaw.
Those pocket doors hang up on the smallest obstruction and a real witch to repair once stuck.
Mike
"I'm not as green as I am cabbage looking"
woody4249 is offline   Reply With Quote
Old 07-07-2012, 02:46 PM   #8
Mike
Are you really saying cats do not care about finish carpentry? Just checking!
Your point about pocket doors being a witch to repair is a lesson I have had to relearn so many times. I hate the things. Last one I had to deal with the client insisted there must be a way to get matchbox cars her psychotic kid tossed in the pocket out and straighten the top track and brackets without opening a wall.
I also have visions of my cat Spikezilla. 25 pounds of orange tabby with an attitude. Fearless, enterprising, nice but not easily stopped by something like a pocket door. He would have head busted it until it opened with assistance or because its hardware failed. If I cut a hole in it for him in response? He would have remembered how much fun the head busting was, the attention he got and ignored it. Some say I should have called him "God&%$%%@* Spike" because they heard me call him that most often. He attracted nice women though so I kept him for many years even after securing one special.
He would have loved more holes in walls though. I argue again for making the opening in the wall and not the door. Drywall is easy to fit and replace when done with the cat or selling the house. It is pretty hard to patch a pocket door.
The Following User Says Thank You to user1007 For This Useful Post:
Old 07-07-2012, 06:18 PM   #9
This is why I love this place, you get different Ideas and thoughts behind a project.
Never thought of the wall, have seen it done before, That does sound like the best if you can do it.
How to repair a hole in cast Iron pipe? bofusmosby Plumbing 26 11-13-2011 10:35 AM
Sump hole and water drain questions Ncasalejr Plumbing 1 06-21-2011 10:57 AM
Installing Mammoth Basketball Goal - Size of Hole? keady27 Building & Construction 1 03-29-2011 09:07 PM
pocket door between kitchen and laundry jarleifvaagen Building & Construction 7 02-13-2011 08:55 AM
Fixing 11" Hole in Concrete Foundation robertr4836 Building & Construction 6 02-04-2008 09:08 AM
