Pocket Door Adjustment - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-21-2012, 03:13 PM   #1
pocket door adjustment
i have a gap when closing my pocket door...when i turn the adjusting bolt it doesnt raise or lower the door....what am i doing wrong
onaroll is offline   Reply With Quote
Old 12-21-2012, 03:17 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 114
If you are talking about the nut on the roller hardware, that is for locking the bolt in place, check to see if the bolt itself is turning.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 12-22-2012, 10:44 AM   #3
AHH, SPANS!!!
Rewards Points: 1,166
if you lift the door a tiny amount with a shim it will help to figure out the tightening/ loosening part of the door without the weight of the door hindering your efforts. there should be a threaded bolt that has a special wrench that goes up or down with the wrench
hand drive is offline   Reply With Quote
The Following User Says Thank You to hand drive For This Useful Post:
BigJim (12-22-2012)
Installing Switch in Pocket Door Wall JulesB Electrical 25 11-19-2014 12:40 PM
pocket hole jointery and cabinet screws for framing newbymodeler Carpentry 29 03-07-2013 04:17 PM
Pocket Door Wheel AZSun Carpentry 2 10-09-2012 10:01 PM
pocket door between kitchen and laundry jarleifvaagen Building & Construction 7 02-13-2011 08:55 AM
pocket hole joinery for cabinet doors? Jeremy Hillary Boob, PhD Carpentry 4 03-09-2009 06:26 PM
