-   -   pocket door adjustment (http://www.diychatroom.com/f14/pocket-door-adjustment-167079/)
onaroll 12-21-2012 02:13 PM
i have a gap when closing my pocket door...when i turn the adjusting bolt it doesnt raise or lower the door....what am i doing wrong
BigJim 12-21-2012 02:17 PM
If you are talking about the nut on the roller hardware, that is for locking the bolt in place, check to see if the bolt itself is turning.
hand drive 12-22-2012 09:44 AM
if you lift the door a tiny amount with a shim it will help to figure out the tightening/ loosening part of the door without the weight of the door hindering your efforts. there should be a threaded bolt that has a special wrench that goes up or down with the wrench
