Pneumatic Nails - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-14-2011, 05:02 AM   #1
Pneumatic Nails
Are all pneumatic nails interchangeable. Can I use Bostitch w/ Porter Cable or Paslode w/ Dewalt. I have several guns do I need to keep separate nails or will 1 manufacturer do it all? Thanks
FCAB is offline   Reply With Quote
Old 07-14-2011, 05:46 AM   #2
DIY staff
Rewards Points: 7,174
The brand doesn't matter as long as the nails fit the gun.
All my brad guns use Porter Cable nails even though they are three different brands.
Avoid super cheap nails as they seem to bend and jam.---Mike---
Old 07-14-2011, 06:31 AM   #3
What he said, if they fit you can probably use them. But not all manufacturers nails fit other guns. When in doubt, do what the manufacturer recommends.
Old 07-15-2011, 06:38 AM   #4
in my very limited experience, finish nails are easy to mix and match, so long as the gauge is the same. Framing nailers on the other hand, have several criteria which determine whether or not they will fit, so its harder to use non manufacturer nails.
1910NE is offline   Reply With Quote
Old 08-12-2011, 10:28 PM   #5
Most finish nails are interchangeable as long as you have the correct gauge and angle or straight.
Framing nails are more complex. In a nutshell: 20 degree tools use 20 or 21 degree nails; 28 degree tools (mostly Bostitch) need 28 degree nails; 30, 31 degree tools can use 30-32 degree nails. Brand doesn't really matter as far as functionality, but keep in mind that generics are made to run thru a wide variety of tools. Branded nails are designed to work flawlessly with their brand tool.
Clear as mud right????
abitawheat is offline   Reply With Quote
Old 08-13-2011, 05:27 AM   #6
KemoSabe
loneframer's Avatar
Not all guns are created equally.
It's not that it took him an hour to make 100 bucks, it's that it didn't take you 10 hours to save 100 bucks.
loneframer is offline   Reply With Quote
Old 08-13-2011, 06:40 AM   #7
Not so new
12penny's Avatar
Rewards Points: 520
Showoff!
12penny is offline   Reply With Quote
Old 08-13-2011, 06:45 AM   #8
DIY staff
5 pinners? I know they are cheap but five?
Old 08-13-2011, 12:16 PM   #9
KemoSabe
loneframer's Avatar
Actually, I only have 2 micro-pinners, one of which was absent for the photo.
I do have a bunch of brad nailers, some 1.25" max and several 2" max fastener length. Some of the guns you see are 1/2" crown staplers, 1/4" crown staplers, combo brad/staple guns... Some where bought on a shoestring budget and others are upgrades as funds would allow. Others were bought with the sole intention of lending them to neighbors.
Old 08-13-2011, 12:31 PM   #10
Framing Contractor
Depends on what type of gun you have. Finish nailers have straight and angled nails. Alot of finish guns can use the same nail. Framing nailers have angled nails but the degrees are different between the brand gun you have. Most coil framing nailkers can use the same nails.
Joe Carola
Joe Carola is offline   Reply With Quote
33 vs 35 Nails Dilemma banzaitoyota Tools 1 12-28-2010 06:44 AM
nail guns & nails koodawg Tools 4 12-06-2010 10:05 PM
What nails to use? 2x4 framing, osb sheathing jw15842 Carpentry 6 09-08-2008 10:31 PM
Which nails are right for the job? MIKEGOUGH1 Building & Construction 2 12-16-2006 10:54 AM
