Plywood For Subfloor - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 01:00 PM   #1
plywood for subfloor
what nail size do you use for the plywood on the subfloor
phillipc17 is offline   Reply With Quote
Old 04-05-2011, 02:03 PM   #2
8d nails will do the trick. I recommend using some pl400 subfloor adhesive on your joists before laying your subfloor down to eliminate squeaks down the road.
XXwilsoXX is offline   Reply With Quote
Old 04-05-2011, 07:09 PM   #3
Unless you are talking about an underlayment going on top of your subfloor???
Old 04-05-2011, 08:56 PM   #4
Rewards Points: 272
If this is your own home I would recommend using screws. There is such a thing as flooring screws and they don't tend to come out causing squeaks. Have done this to my entire house and it is nice not to hear any noisy squeaks when walking.
cheers
fixrite is offline   Reply With Quote
Old 04-09-2011, 11:28 AM   #5
screws are great or ring shank nails home depot used to rent a tool that is a screw gun on a long handle so you can screw off an entire house and not kill your back. I forget the name of the tool but it uses belt fed screws. personally I use a stick nailer with the ring shanks, good luck, dont forget the glue.
airborne82 is offline   Reply With Quote
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 07:47 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
