Plywood Shed Floor Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-02-2009, 11:16 PM   #1
plywood shed floor question
Im building a floor for my shed I started screwing down the exterior ply wood to the frame and it says this side down (smooth side) Does it really matter? Thank you
jmhdwnsth is offline   Reply With Quote
Old 07-03-2009, 06:12 AM   #2
As far as looks go, yes, but for weather protection, probably not.
Old 07-03-2009, 09:00 AM   #3
Remodeler
adpanko's Avatar
Rewards Points: 150
I agree, don't worry about it. I personally would put the smooth side up since that is what you'll see and it will also be easy to keep clean than the rough side. But it shouldn't matter for protection purposes.
adpanko is offline   Reply With Quote
Old 07-03-2009, 09:26 AM   #4
Thank you. That is what I figured, just wanted to make sure.
Wiring a Shed and Garage abedj Electrical 1 05-08-2009 11:09 AM
shed plywood floor: treated? flamtap Building & Construction 6 04-24-2009 05:05 PM
shed floor plywood layout? flamtap Carpentry 4 04-24-2009 11:20 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 12:11 PM
Shed Wiring bcdal Electrical 12 03-26-2008 04:51 PM
