Plywood Sheathing Vs Subfloor Vs Underlayment - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 10:40 PM   #1
Plywood sheathing vs subfloor vs underlayment
What's the difference? I see plywood available specified as either sheathing, subfloor or underlayment. But other than thickness, I don't see a difference. And even then, some thicknesses overlap in the categories.
acerunner is offline   Reply With Quote
Old 06-10-2011, 06:36 AM   #2
DIY staff
Rewards Points: 7,174
Google Plywoods grade The explanations there are good and easy to understand
Exposure 1 (or X for exterior) means water resistant glue--that's key for your bath floor
You don't want the wood delaminating.
The letters have to do with the quality of the faces--D-ugly with open knots--C less ugly-patched knots--B not bad A--smooth and sanded
The other numbers are for the core---weather voids are in there or not--number of plys.
3/4" CDX tongue and groove is the most common subfloor---This is not the preferred subfloor for tile--it has open knots and some voids--BCX is the better choice---
I've never had an issue with CDX---it what the builders use most--
Google ---Mike---
Old 06-10-2011, 06:46 AM   #3
What he said, but to be less specific........sheathing and subfloor are generally the same stuff, CDX(1 side C/1 side D/exterior grade glue). OSB is more common now than plywood, less expensive. Subflooring is usually T&G, sheathing is not. Underlayment bridges the large imperfections of subflooring, as a prep for finish flooring.
Old 06-10-2011, 12:14 PM   #4
so underlayment would typically be the thinner stuff?
i asked in another thread about laying hardwood flooring parallel to plank t&g subflooring (although that makes it perpendicular to joists), and was told I need at least an additional 1/2" subfloor. So I went to HD and they had the 3 types of plywood. not sure which to use. Almost sounds like underlayment is what I need since the existing plank is the true structural support...
Old 06-10-2011, 08:24 PM   #5
DIY staff
You need structure--in this case --nail holding ability--1/2" BC will support and hold nails for that wood floor.
Old 06-11-2011, 10:46 PM   #6
Registered User
Rewards Points: 5,516
http://bct.nrc.umass.edu/index.php/p...ient-flooring/
http://www.apawood.org/pablog/index....-Floor-Systems
http://www.apa-europe.org/Languages/.../PDF/R340G.pdf
Gary
Old 06-24-2011, 09:31 PM   #7
Framer
Very easy,
sub floor is always tongue and groove and minimum 5/8's (in our days at least)
sheathing is plywood that butts together with no groove and minimum thickness for walls is 3/8's
underlay is a product to deaden sound under laminate flooring..
hope that helps
joeyr is offline   Reply With Quote
plywood/ osb scraps for sheathing? nicole21 Roofing/Siding 4 09-08-2010 10:41 AM
Considering replacing playwood subfloor, many questions. gante Flooring 3 04-12-2010 11:39 PM
How to install 3/8 underlayment plywood? dangdang Flooring 8 09-26-2009 04:21 PM
Removing tile from plywood underlayment Martinglmt Flooring 3 12-13-2008 07:06 PM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 07:44 PM
