Plywood Optimzer Anyone? - Carpentry - DIY Chatroom Home Improvement Forum
Old 12-28-2013, 06:09 AM   #1
MarginallyQualified
Rewards Points: 2,464
plywood optimzer anyone?
Does anyone know of an easy to use free online optimizer?
Or is anyone with a good one willing to punch in a few number for me?
Thanks.
3/4" MDO ...
panel saw cut at Home Center or lumber yard:
48x32
62 x18
10 x18
49 1/2 x18
76 1/2 x18
80 x18 5/8
80 x18 5/8
49 1/2 x8
87 3/4 x3
87 3/4 x8
87 3/4 x161/2
31/2 x12lf
3 x6lf
1 x14lf
Old 12-28-2013, 06:57 AM   #2
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,334
just get some graph paper and make a bunch of templates on it then map out your cuts. its the easiest way to figure out your cuts
woodworkbykirk is offline   Reply With Quote
Old 12-28-2013, 07:45 AM   #3
MarginallyQualified
BTDT.
thank's for the suggestion.
Old 12-28-2013, 08:12 AM   #4
Rewards Points: 240
what are you making ?
i may have to do the same thing. i am kicking around the idea of making new subwoofers.
2 18" drivers, ported.
Fix'n it is offline   Reply With Quote
Old 12-28-2013, 02:20 PM   #5
MarginallyQualified
Cabinet in the carport for yard tools, a stoop by the back door,
a shelf there, and a new attic hatch.
Wanna come by and help?
Steak and beer on me.
Old 12-28-2013, 04:07 PM   #6
typically what i do is break down a sheet layout based on my widest rips first.. then mark out each panel for that width. if you have waste from that use those for your small pieces.
Old 12-29-2013, 09:05 AM   #7
Rewards Points: 240
we both wish
repairing rotten trim and plywood above garage abacker Roofing/Siding 33 10-21-2013 01:57 PM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
plywood damaged by water hendjl Building & Construction 4 11-03-2009 06:47 AM
