Plywood Counters - Carpentry - DIY Chatroom Home Improvement Forum
Old 10-12-2011, 08:42 AM   #1
plywood counters
I would like to see if i can get some advice on some countertops that will be for my wifes craft room and also a computer workspace.
I was already planning on installing the speed brace system but was wondering what type of plywood to purchase and what kind of polyurethane to get (durable).
Also how to finish the edges of the wood. Is it just flat molding nailed and glued?
rustic is offline   Reply With Quote
Old 10-12-2011, 09:15 AM   #2
Rewards Points: 150
I would use laminate, very durable for that type of application.
josall is offline   Reply With Quote
Old 10-12-2011, 09:37 AM   #3
Rewards Points: 190
Flush doors make a good countertop-light, stable,inexpensive and the edges are already finished. Use water base poly.
zircon is offline   Reply With Quote
Old 10-12-2011, 10:14 AM   #4
I should have mentioned i didnt want laminate.
The door suggestion is definately something i will consider.
thanks
Roofing plywood advice needed jimd206 Roofing/Siding 2 04-25-2011 12:58 AM
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 03:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 06:08 PM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-14-2010 12:09 AM
Hardwood Subfloor: OSB vs. Plywood vs. OSB + Plywood italoblu Flooring 2 07-31-2008 01:11 PM
