Plywood Baseboard - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-05-2011, 10:22 PM   #16
The door in the attached image is similar to our new doors. The second photo shows the cap. When considering plywood for the 6" baseboard, I was thinking that a solid oak cap like in the picture would dress out the baseboard nicely.
At this point, I'm still comparing options. I need to get to a good ole lumber yard for prices on oak.
DoItMyselfToo is offline   Reply With Quote
Old 04-06-2011, 11:45 AM   #17
If you use plywood, then biscuit joints might be a good option for the ends.
You might think through which areas will be more visible -- There might be some rarely seen areas where pretty much anything brown would work, and there might be some that you'll look at all the time.
Likewise, you might have a lot of short runs, and other areas where the joints can be mitigated.
pyper is offline   Reply With Quote
Can I tile over old plywood with no gaps? JFERTICH Flooring 5 02-21-2011 02:52 PM
Can I use Thin Set Mortar over Interior Grade Plywood? JFERTICH Flooring 1 02-19-2011 05:08 PM
Problem with 240V Elect Baseboard Heater JRHP Electrical 4 10-04-2010 09:30 AM
Fixing a screwup - stain on oak plywood brich Carpentry 9 05-13-2010 11:09 PM
Baseboard dilema Allyson Flooring 5 09-04-2009 08:30 AM
