Ply Ceiling - Carpentry - DIY Chatroom Home Improvement Forum
Old 08-26-2008, 07:57 PM   #1
ply ceiling
I used ply to do my ceiling instead of sheet rock, can some one tell me what to use for the joints. or what I mean is how to do the seams. thanks
pwright is offline   Reply With Quote
Old 08-26-2008, 09:00 PM   #2
Registered User
Termite's Avatar
Welcome to DIY Chatroom!
What sort of finish are you trying to accomplish? I'm certainly hoping that you intend to have the plywood serve as a substrate for another material, such as a stamped tin ceiling. If not, why on earth would you want a plywood ceiling over a sheetrock ceiling?
Old 08-27-2008, 06:20 AM   #3
Whatamess
You can 3/4" screen mold if your joints are tight enough. If not rip some 1/4" thick pieces out of 2x4's.
I may go home hungry, but not tired and hungry.
TazinCR is offline   Reply With Quote
Old 08-27-2008, 06:49 AM   #4
Wouldn't this also be a huge fire hazard if something horrible was to happen? I was always under the impression that code required some sort covering such as Sheetrock or tin.
retro is offline   Reply With Quote
Old 08-27-2008, 08:54 AM   #5
Registered User
Termite's Avatar
Not a code issue in single family residential construction. But, I like your thinking.
Old 08-27-2008, 10:16 AM   #6
Licensed Contractor
Interesting choice. I've seen several of these, but usually in a rustic cabin. You have several choices. If you intend on leaving the plywood exposed, you can buy lattice strips and nail them across the seams, making your ceiling into a giant sheet of graph paper. It looks a little hack, imo, but to each his own.
A client once asked me to remove the strips from their ceiling and, without ripping down the ply, finish off the ceiling like it was drywall. So, I removed the strips, primed the surfaces, then mixed some setting compound and finished the ceiling like it was drywall. The perimeter edges were covered by bed molding, which I just put back up.
Or, you can cover the ply with tin, beadboard, whatever.
Good luck.
Renovator,LLC is offline   Reply With Quote
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Drywall ceiling: Water Damage, looking for advice dawho1 Building & Construction 11 09-13-2010 10:05 AM
Ceiling condensation icemand Building & Construction 1 12-15-2009 05:16 AM
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Pot lights in a drop ceiling Howdy Electrical 3 03-14-2008 08:23 PM
