#1 |
Plinth Block Height
When casing in a door opening that opens to rooms with different floor heights, should the plinth block be cut to keep the height parallel across the top of the two plinths blocks or should the plinth block be kept the same size regardless of floor height?
(I haven't nailed in the blocks awaiting feedback) |
#2 |
Stairguy
Plinth Block Height
I would say it is a matter of preference. I would rather see the tops at a level height.
| Display Modes | |
| Vinyl Window in Concrete Block | Wrongwrench | Carpentry | 4 | 12-07-2010 11:21 AM |
| Door opening in load bearing block wall | SS396 | Building & Construction | 12 | 09-13-2010 06:27 PM |
| Fire blocking a wood stud wall built against cinder block. | BasementVirgin | Building & Construction | 1 | 10-06-2009 12:02 AM |
| Installing plinth blocks? | Badfish740 | Carpentry | 6 | 02-09-2009 11:45 AM |
| Marrying a sloping stone wall to a cinder block wall. | mrdol | Landscaping & Lawn Care | 1 | 11-09-2007 05:08 PM |
