"Platon" Basement Subfloor Project $0.80 Per Sq Ft. - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-03-2011, 12:11 PM   #1
"Platon" Basement Subfloor project $0.80 per sq ft.
just finished installing 1" Dow Foam on basement walls (39 sheets), and the Certainteed Floating Platon subfloor (3 rolls, 7'3 x 65'), and 40 some sheets of 3x4" T&G on top of the Platon system. Had a spray foam installer shoot the rim joists.
Basement is so much warmer ! Basement was dry with no issues prior to installation.
approx 1300 square feet.
System went down in 4 days, not working very hard. Mid-northern Michigan area.
DriLock ( Dry Lockv ) panels were $1.57 per sq ft. if I went that way.
hoosiername is offline   Reply With Quote
basement causing suction on basment door BlueBSH HVAC 3 06-08-2010 02:26 PM
Remodeling basement: Moist foundation gordonf238 Building & Construction 8 04-25-2010 06:50 PM
Basement Renovation Project Howdy Electrical 6 03-13-2008 11:07 AM
Basement - need to bust up about 1 ft deeper FallenAngel Building & Construction 7 08-15-2007 09:09 AM
Sub Basement Walkout - Please Help pgs_28 Building & Construction 11 08-12-2007 09:55 PM
