Plastic Laminate Countertop, Gaps Between Pieces - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-21-2014, 01:00 AM   #1
plastic laminate countertop, gaps between pieces
I installed new plastic laminate over an existing plastic laminate covered countertop than is 30 feet long. After several days the gaps, the butt joints, between pieces, which were tight upon completion, started to open. The new material was acclimated for 3 days before installation. What happened? How do I correct?
feickja is offline   Reply With Quote
Old 02-22-2014, 02:03 PM   #2
Rewards Points: 144
Installer error.I would never install laminate over laminate.How did you seam the butt joints ?Were they over an existing joint on the old laminate or substrate?Did you let the glue build up at the joint? Did you roll the joint out?
Pics would help.
mako1 is offline   Reply With Quote
Old 02-22-2014, 04:34 PM   #3
Ole Wood Worker
BigJim's Avatar
Rewards Points: 506
At this point all you can do is start over or buy some seam filler that matches the HPL, not much else can be done.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
laminate countertop help moni71487 Interior Decorating 18 10-03-2012 06:39 PM
Building Laminate Countertop... ARB Carpentry 7 08-20-2012 05:23 PM
Granite Tile vs. Laminate Countertop (Kitchen) Cow 9 Kitchen & Bath Remodeling 7 01-25-2012 11:53 AM
Cutting Laminate Countertop From Lowes ryanb4614 Building & Construction 3 12-29-2011 04:26 PM
Laminate Kitchen Countertop Ken Johnson Remodeling 2 11-21-2007 12:10 AM
