-   -   Plastic on basement wall (http://www.diychatroom.com/f14/plastic-basement-wall-55074/)
kupalino 10-13-2009 12:45 PM
My house is 4 years old and has a walk out basement and the builder put plastic on the walk-out side wall, the 3 other walls are cement. My question is, I'm finishing my basement and I'm wondering if I should keep the plastic and put drywall on top of it or remove the plastic? I'm not sure what the plastic is for, vapor barrier? or just to cover up the fiber insulation for the meantime?
Thanks.
12penny 10-13-2009 01:15 PM
kupalino....if the insulation is'nt paper faced, leave it.
baum 10-15-2009 09:29 AM
On the walls that you build and butt up to it have that vapor barrier overlap in the corner and use a "house wrap" type tape to seal the 2. If you dont use paper faced insulation. Non paper faced insulation is alot cheaper.
Scuba_Dave 10-15-2009 09:37 AM
Is the walk out wall a wood framed wall?
kupalino 10-15-2009 12:45 PM
yes, the walk out side wall is wood framed wall with unfaced batt insulation.
12penny 10-15-2009 12:47 PM
Leave the plastic.
Gary in WA 10-16-2009 03:05 PM
http://www.buildingscienceseminars.c...w&Retrofit.pdf
http://www.buildingscience.com/docum...gs?full_view=1
Be safe, Gary
