#1 |
Plans or technique for a simple sliding door?
I recently built a partition wall to segment a small section of our unfinished basement and now need to go about installing a sliding door to finish it off (wall mounted sliding track hardware is already in place). The problem: I don't have a door and it looks like we'll need to build one, approx 48"w x 66"h. Most of the plans I've dug up are for simple rail and stile doors, but I don't own a table saw or router table to make the necessary cuts for the grooves and don't intend on getting one just for this project.
Any advice on building a cheap, sturdy panel door using other joining techniques? The only real requirement is that the top edge of the frame be thick enough to securely attach the mounting hardware (1.5" screws mounted vertically through the top). Other options I've seen are for barn doors which would be overkill here and too heavy for what we want. The only function of this door is to keep pets on one side of the partition wall. It doesn't have to be pretty, it could be a screen door for all we care! Thanks |
#2 |
Not impossible to do with a circular saw, but you at least need a straight edge for a guide. Mortise/tenon joints are best, and were done long before power tools, just slower. Trim molding can take the place of routed edges. Raised panels, however, are hard to do without power tools, flat panel no problem.
#3 |
I'd be concerned about hanging a door using screws driven vertically in the top edge. They will likely pull out fairly soon. Most sliding barn door type hangers mount with horizontal screws through a horizontal plate.
What tools do you have for this project? You might look at using beadboard paneling for the panel of the door. |
#4 | |
Plans or technique for a simple sliding door?Quote:
| Display Modes | |
| Looking for plans to build a simple captains platform bed with NO DRAWERS | newbuild2010 | General Discussion | 0 | 01-02-2010 03:30 PM |
| sliding patio door header... | sharp | Remodeling | 2 | 11-03-2009 04:50 PM |
| Rehanging an exterior basement door | tputkey | Building & Construction | 9 | 05-21-2009 04:19 PM |
| Entry Door---My Story----Advice Please | rossmoor | Building & Construction | 3 | 02-29-2008 10:13 PM |
| Installing sliding patio door | nicksr | Remodeling | 2 | 01-05-2008 10:44 PM |
