Pig's Ear Handrail - Carpentry - DIY Chatroom Home Improvement Forum
Old 01-23-2008, 03:25 PM   #1
Pig's Ear handrail
Hi. Does anyone know how to fix Pig's Ear handrail to the wall?
Cheers!
woodyjohn is offline   Reply With Quote
Old 01-23-2008, 06:43 PM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,060
Ayuh,...... I've never tried it,.....
But, I'd think that running screws right in thru it just under the area your hand rides onto, directly into the wall otta do it......
Bondo is online now   Reply With Quote
Old 01-24-2008, 08:27 AM   #3
Thanks for that. Seems a little course to do it that way - was wondering if there is a way to do it that's hidden from th outside, or special brackets...
Old 01-24-2008, 09:27 AM   #4
Bondo's Avatar
Ayuh,....
Can can always countersink the screws,+ either putty over them, or use wooden cap/ plugs to hide them......
Old 01-26-2008, 11:46 PM   #5
remodeling pro
Drill and counterbore for plugs in the curved bottom section, then screw to the wall with long pan head screws. Install plugs of the same wood species, orientating the grain with the grain of the rail, sand flush ,and finish.
troubleseeker is offline   Reply With Quote
Old 01-27-2008, 06:50 AM   #6
Lic. Builder/GC/Remodeler
AtlanticWBConst.'s Avatar
There you go... the answer, I concur.
Also, make sure that you use proper, strong, appropriate length wood screws.
- Build Well -
Old 11-27-2014, 09:24 PM   #7
Rewards Points: 16
John, where did you get your pigsear handrail? I'm looking for them and not having any luck.. I can find tons of sites selling them in the UK but none in North America..
cyric_74 is offline   Reply With Quote
Old 11-28-2014, 12:38 AM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 302
This is an old thread, chances are the OP won't see this post. I don't know where you can get the rail here in the USA but I disagree with the way to mount it to the wall. If that is fastened to sheet rock without a backer it isn't going to be sturdy because it will dig into the sheet rock with a little pressure.
Use a 1X4 (as an example), round over the edges, using glue between the rail and 1X, screw into the rail from the backside of the 1X. Screw at an angle to keep the screws from running out of the rail. Glue and screw or nail the 1X into studs.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
The Following User Says Thank You to BigJim For This Useful Post:
Doc Sheldon (11-28-2014)
Old 11-28-2014, 01:47 AM   #9
Okay, this might be the key...
ron45 is offline   Reply With Quote
Old 11-28-2014, 03:08 PM   #10
Doc Sheldon's Avatar
Rewards Points: 400
Having made a similar mistake of not using a backer board, I'd agree with Jim. Drywall's going to compress and that handrail is just going to get loose. If installed well, it may save someone a bad fall... if not, it could be to blame for one.
Doc Sheldon is offline   Reply With Quote
handrail ends farrington135 Carpentry 12 05-23-2013 01:51 PM
Solo handrail for outside?? bujaly Carpentry 3 05-22-2007 11:55 AM
Installing a handrail handbanana Carpentry 14 03-29-2007 04:14 PM
Can Durock Build an entire house? chatman General DIY Discussions 10 12-31-2006 12:35 PM
