Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 01-03-2008, 12:37 PM   #1
picture window
I'm replacing a big picture window. It has a picture window in the middle with a single hung window on each side of it. I have another big picture window the same size as the old one and some double hungs to replace the single hungs. I've installed double hungs before but I've never had more than one window in one opening like this before. If anyone knows how to do this or has done it before I'd like to hear from you. thanks
matjone is offline   Reply With Quote
Old 01-03-2008, 03:29 PM   #2
picture window
Is the old window one unit?
jerryh3 is offline   Reply With Quote
Old 01-03-2008, 06:43 PM   #3
picture window
I think it must have a jamb in between the units, because I looked closer today and it has brick molding in between the windows and trim in between on the inside.
Old 01-03-2008, 07:00 PM   #4
picture window
Do you have any pictures?
Old 01-03-2008, 08:04 PM   #5
picture window
no pictures.
Shrink Film Window Insulation miserlou General Discussion 10 11-24-2008 07:19 AM
Non-load bearing window header in exterior wall timelyirony Building & Construction 3 12-08-2007 05:15 PM
Vinyl window stuck in wood frame rlcarter Remodeling 7 09-26-2007 06:29 PM
Replacing aluminum window with a vinyl one? Doug Crf Building & Construction 2 04-23-2007 05:49 AM
