Picture Framing Deck - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-12-2011, 06:02 PM   #1
I am building a 10x12 composite deck with vinyl railings. I am having trouble with the framing detail to accomplish the picture framing. I am going to picture frame with one row around the deck. Can some add a framing detail for this? I will also have to frame around the pressure treated 4x4's needed for the vinyl railing.
2x8 framing
5' off the ground
4' wide stairs
taylor01 is offline   Reply With Quote
Old 04-12-2011, 08:07 PM   #2
kwikfishron's Avatar
Rewards Points: 764
You just need to add framing as needed. Block every 16 or 24” when the joist run parallel. Head out around post etc.
kwikfishron is online now   Reply With Quote
Old 04-13-2011, 07:00 AM   #3
I wasn't sure if the blocking would be better or if I should just double the outside joist to pickup the picture frame decking and then double the joist where the end decking would land up against the picture framed decking.
Old 04-13-2011, 01:29 PM   #4
Next Time...New Build
Rewards Points: 150
I have always run a 2x6 along the entire outside. Were it is parallel, add blocking 1.5" below the top of the joist and the 2x6 will rest on top of that. This will give you continuous framing along the outside and will provide ample screwing/support for your ribbon (aka picture frame).
Also, this gives you a lot of flexibility in figuring the amount of overhang you want.
RickyBobby is offline   Reply With Quote
Ground level deck - screws or bolts? rsmith0399 Building & Construction 9 01-11-2012 12:53 PM
deck - beam to post connection (??) brocasArea001 Carpentry 21 05-11-2011 08:39 PM
Deck Addition - Floating to Attached Foundation eemichael83 Project Showcase 15 08-22-2010 09:40 PM
Tips for my floating deck DIYguy2000 Building & Construction 13 06-18-2010 07:34 PM
Tub Deck Framing FlyBoyd Carpentry 3 10-18-2008 11:32 PM
