Picture Frame Wainscoting - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-02-2013, 02:46 PM   #1
Rewards Points: 137
Picture frame wainscoting
I am finishing up the babies room. I would like to do picture frame wainscoting but I am not sure what size boxes to use on each wall. The right wall is 147 inches long and the left wall is 118 inches long due to the closet that takes some of the room on that side. The front wall has the window. I am not sure if it would look better with the same size boxes on each side and different spacing or different size boxes. I think I would use 2 small boxes and 2 longer but lower boxes on the wall with the window.
Any ideas would be appreciated.
Troy32 is offline   Reply With Quote
Old 09-02-2013, 07:33 PM   #2
recently retired
Rewards Points: 280
First I would suggest removing the the chair rail and bringing it in line with the window, then trimming out the window.
Keith Mathewson is offline   Reply With Quote
The Following User Says Thank You to Keith Mathewson For This Useful Post:
woodworkbykirk (09-02-2013)
Old 09-02-2013, 08:07 PM   #3
journeyman carpenter
woodworkbykirk's Avatar
Rewards Points: 1,326
keiths right, by moving the chair rail to the same height as the window apron you will have one clean line all the way around the room
woodworkbykirk is offline   Reply With Quote
Old 09-02-2013, 09:11 PM   #4
Rewards Points: 137
And butt right into the window stool? I do not like that look.
Old 09-02-2013, 09:38 PM   #5
Jay123's Avatar
Hey Troy...I did something very similar on a client's home a few years ago, it came out pretty well..
http://www.craftsmencarpentry.com/judges_paneling.htm
You may have to go through some of the pics (I think it's around pics #13-14), but it was a VERY similar situation as yours.
Cheers.
Jay123 is offline   Reply With Quote
Old 09-02-2013, 09:45 PM   #6
Jay123's Avatar
I'm looking for some finished pics, but the table blocks most of 'em.
Sorry...
Drawing...
Old 09-02-2013, 09:58 PM   #7
Rewards Points: 137
I would like to trim the window but the sides were not perfectly straight from the builder. I would have had to rip the whole sheet rock return out. Baby on the way and wife growing impatient I did the next best thing.
Old 09-02-2013, 10:02 PM   #8
Rewards Points: 137
Jay - that is some amazing work. It really helps with what I am doing. If you explained to me the natural wood columns mixed in with the white trim I would have thought it would look horrible. Seeing it done it looks incredible. Well done
Old 09-02-2013, 10:09 PM   #9
Jay123's Avatar
Thanks, Troy. The illustrations were to show you that you can make the "boxes" below the window smaller (like I did), and still keep what you have. It will work well for what you've already done.
Cheers.
Old 09-02-2013, 10:25 PM   #10
Rewards Points: 137
I got side tracked. Haha. I am trying to see how I can incorporate some natural wood columns.
Old 09-02-2013, 10:32 PM   #11
Jay123's Avatar
Now you're really screwed.
Old 09-03-2013, 01:55 PM   #12
no.. the apron and chair rail all become one thing so the chair rail isnt interupted under teh window stool
Old 09-04-2013, 05:46 PM   #13
Rewards Points: 137
I did some research before I started and was going to continue the chair rail under the stool as the apron as you suggested. I did not love the look although it may be technically correct. The wife did not like it either as she wanted the chair rail higher. She likes the way the returns look.
I am just a weekend warrior. First time spackling, painting and installing flooring. Will be first time installing moulding as well. Learning a lot as I go.
Old 09-04-2013, 07:26 PM   #14
recently retired
Rewards Points: 280
Here is some additional research for you http://www.thisiscarpentry.com/2010/...ed-chair-rail/
Old 09-04-2013, 07:55 PM   #15
Rewards Points: 137
Great article. I did read that a while back. There are many schools of thought on the height. I actually showed it to the wife while we argued about the height. Haha. Basically it comes down to what you thinks looks good.
Deck picture framing question - ripping boards chrisv2 Building & Construction 0 06-21-2012 12:21 PM
Moving a internal door frame Marie1 Building & Construction 2 05-19-2012 08:08 PM
Diy picture frame light sack17 Interior Decorating 2 05-16-2012 08:58 AM
storm door frame vcerilli Carpentry 1 11-05-2011 02:35 PM
wainscoting picture frame dvatt Carpentry 1 12-21-2010 06:22 AM
