Pergola - Strong Ties - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-22-2011, 12:27 PM   #1
I'm building a basic wood pergola over my back patio. I will be pouring concrete to extend the patio which I'll build the pergola over, so I can pour my corner footings rather than drilling into existing concrete.
I'm trying to figure out what is the best tie down for 6x6 corner posts. I found this catalogue from Simpson, and am wondering if anybody has done this before and has a recommendation?
http://www.strongtie.com/ftp/catalog...09.pdf#page=10
Thanks!
Tyler Borders is offline   Reply With Quote
Old 05-22-2011, 01:24 PM   #2
Rewards Points: 1,016
I used the AB - drilled hole in the concrete and inserted expanding anchor bolt.
The biggie is to have athe spacer under the post to keep it from direct contact with the concrete, elevated from being in water, and to dry out throughly.
Old 05-22-2011, 02:32 PM   #3
Stairguy
Millertyme's Avatar
Rewards Points: 508
i agree on the AB's. That is what I always use for deck posts.
Millertyme is offline   Reply With Quote
Old 05-22-2011, 03:25 PM   #4
AB Tie
Thank you both. Is this true even if I pour my own footings and don't have to drill into pre-existing concrete? I'm just looking for the most structural support, and being that I will pour fresh I'm wondering if there's any difference.
Thanks,
Tyler
Old 05-22-2011, 03:54 PM   #5
Civil Engineer
Rewards Points: 4,514
If you are pouring the footing new, you can use the Simpson model that attaches to the pier with the J bolt in the concrete. That's what I used for my 6x6 post attachments to the concrete footers for my deck.
Old 05-22-2011, 04:00 PM   #6
Thanks, Daniel. Would that be this one? http://bit.ly/kKs4qR
Tags
pergola , posts , tie
Attaching a pergola to a home and deck. nickf829 Building & Construction 1 03-15-2011 02:20 PM
removing rafter ties: garage conversion neil_9 Introductions 0 09-29-2010 08:55 PM
Adding Collar Ties to make a ceiling Joe1. Building & Construction 18 09-11-2010 10:56 PM
Pergola on Elevated Deck stubits Building & Construction 0 06-19-2010 09:48 AM
Cutting rafter ties ?? scatkins Building & Construction 23 04-13-2010 04:20 PM
