Pergola Span - Carpentry - DIY Chatroom Home Improvement Forum
Old 07-28-2008, 09:34 AM   #1
Pergola Span
I am building a pergola and I have 6x6 pressure treat upright posts. I am wanting to Span a 20 foot distance. What type of of beam would I need to do this. If necessary a can place an upright midway (at 10 ft) but I would prefer not to. The only load on these beams would be 2x6 that lay accross the top of course. These would be about 16ft long. This is my first post so I am hoping this works!
SelahDIY is offline   Reply With Quote
Old 07-28-2008, 02:55 PM   #2
Registered User
Termite's Avatar
There are no span charts or requirements for pergolas since they don't have conventional roofing materials on top of them. Sagging is the real issue. I'm thinking something in the range of a 6x12 will be necessary to look good with the posts and still make the 20' span without too much deflection over time. If there's a lot of dead weight from other materials resting on the beam, I think a center support is in order.
Old 07-28-2008, 07:00 PM   #3
la15ota's Avatar
We also used 6x6's for our posts and our pergola had a 12 ft and 14 ft span. We used 4x6's with 2 ft over hang on each side. On top are 2x4's. The thicker the wood used the less twisting.
la15ota is offline   Reply With Quote
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 08:30 PM
ledger attached to brick for pergola soupdizzle Carpentry 7 07-07-2008 03:43 PM
attaching joists to ledger for pergola question soupdizzle Building & Construction 1 07-02-2008 10:32 PM
beam for pergola woodsglen Building & Construction 4 04-11-2008 07:55 PM
A Beam for a Pergola rv8tor Carpentry 18 10-30-2007 12:01 PM
