Pergola Questions? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-28-2014, 07:55 AM   #1
Pergola questions?
I am a DIY with basic carpenter skills. I am wanting to build a free standing pergola on my lower concrete patio. I am new to these type of forums so please bear with me.
I am building a pergola that is 9'h x 10'w x 28'L. I will be using 2x6 boards across the top 16" on center. I plan to use 6x6 post and 2x10 band boards.
My questions are this:
1. How many post do I need running the length (28') of the pergola? I plan to use a post on each corner and one in the center at 14'. If using 2x10 band boards will that be enough post? Are 2x10s overkill and could I get by with 2x8s?
2. Should I double the band boards? One on the front and back side of the post?
As for the material I am looking into cedar but way to expensive. Has anyone ever used the Microshades cedar tone pressure treated lumber from Menards?
Final question: has anyone ever used a product called rescue it? My decks are 5 years old and look like crap already.
flexcuff is offline   Reply With Quote
Old 06-28-2014, 08:47 AM   #2
Rob
Robpo's Avatar
Rewards Points: 826
If roof is open 2x8 should be ok. If it is sheathed it would depend on snow loads in your area.
Robpo is offline   Reply With Quote
Old 06-28-2014, 09:14 AM   #3
It will be open except for the shading fabric that I will use. I will only have that on during the summer months then remove in the winter. Thanks
Questions about painting (or staining) stairs and door ToHellWithUGA Painting 3 05-31-2014 06:44 AM
Building my First Pergola chucklong55 Building & Construction 3 03-28-2014 05:28 PM
Pergola design question malapp1 Building & Construction 1 07-24-2013 05:56 PM
Pergola on Elevated Deck stubits Building & Construction 0 06-19-2010 09:48 AM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 09:30 PM
