Pergola Framing Question - Carpentry - DIY Chatroom Home Improvement Forum
Old 04-02-2009, 12:09 PM   #1
Pergola framing question
Hello. New to the board. I had a question in regard to my "planning" steps on building a Pergola. It will be 10'x16'. I plan on using 4-4"x6" posts (only the corners). I plan on using 2-2"x10"x16' for the 16' span (i.e., beams) that will be bolted to the posts (I would also use 2-2"x10"x10' for the 10 foot span - bolted to the posts). I was thinking about placing a 2"x8"x10' or 2"x10"x10' in the middle of the 16' span (cross-ways), attached to the 2"x10"x16' beams. This would help with any deflection with the rafters, which will be (2"x4"x16's). My question is, will I have a deflection problem with the 2"x10"s for the 16 foot span (i.e., will they deflect)? As you can tell, there won't be a "heavy" load on the beams. Any input is appreciated. Thanks.
Latechslack is offline   Reply With Quote
Old 04-02-2009, 01:04 PM   #2
Remodeling Contractor
you should be okay. You will see ceiling joist that are spanned 12' using 2 X 8 and must have a higher live and dead loads on them.
Old 04-02-2009, 01:38 PM   #3
Thanks Bob. I may double-up on the 2"x10"x16s beams with each post sandwiched between the beams.
Old 04-03-2009, 06:39 AM   #4
Mold!! Let's kill it!
Rewards Points: 2,012
There is no live load on a pergola and very little dead load for that matter. If you span more than about 8 feet with 2x4s, you need to plan on something to stabilize them. Otherwise they will twist and warp
Garage Framing Question wrldruler Building & Construction 5 08-22-2008 08:26 AM
attaching joists to ledger for pergola question soupdizzle Building & Construction 1 07-02-2008 10:32 PM
Framing Question: How thick the wall that carries plumbing? jaes Carpentry 5 06-18-2008 05:39 PM
Pergola over Deck Question figgyb44 Building & Construction 2 06-10-2008 07:50 PM
stupid framing question amakarevic Building & Construction 12 02-23-2008 03:29 PM
