Pergola Drawing Questions/span/doubler's?? - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-03-2013, 01:30 PM   #1
pergola drawing questions/span/doubler's??
OK: so This is going on a deck, and the outside posts are going to be going from ground, up through deck, and supplying posts for pergola. Inside posts are going to to roughly 8' notched 6x6's that attach to the joist.
2x8's on FIRST and lowest, running away from house so I can get my beam in front of my bay window. NEXT notched on top of that is 2x8's that will supply as my beam, LAST or top, the 2x6's sit on top of beam, notched as well.
QUESTIONS:
Do I have to "double" my 2x8's for strength. there are doubled 2x8's in my 3 spots? (technically 4 at the end but that looks good. )
Is my outside Beam span of 12 ft. sufficient? (using (2) gaped 2x8's)
Is my joist 2x6's x 11ish feet acceptable?
Notes: The circle's on the drawing have a slightly staggered notch from post to post on the left side to cheat my support beam from being into view of my large window.
I have a gutter fyi on the right side of the drawing that is giving me some decent trouble but I'm working on that still.
I do plan to put some 2x2's or whatever they are called on the very top to help the 2x6's stay straight from warping. I didn't want to complicate the drawing. I also may make a side view drawing later of this plan.
thanks for suggestions. I do have some limits on my height with this bay so board size is very limiting.
wood will be all treated yellow pine from lumber yard.
csmonte is offline   Reply With Quote
Old 06-04-2013, 05:21 PM   #2
Rewards Points: 6,089
I can't believe nobody's chimed in yet with some feedback.
anyhow, half your posting is behind the advertising.
how big are you making this (8 foot out x 12 foot long)
Ours is 14 foot out x 20 foot long. We used all 2 x 6 --
redwood...that's how long ago we did it, redwood was cheap
back in the mid seventies.. and yes, it's still solid as a rock.
Two Knots is offline   Reply With Quote
Old 06-05-2013, 04:56 PM   #3
well, I'm pretty decided on putting a support post in the middle of that span, just to make sure, we get some pretty good wind storms here in the Midwest, I'd feel better having that bit extra.
I now have the question of, am I aloud to and should I notch my "guard" posts to flush the edge of deck? This will be my pergola support posts as well. I just read something about not suggesting this. But most decks I see have them notched to slip on the inside of edges of the deck at the outer 2x10's and continue on to serve as guard posts. like picture below, except i am using 6x6 and some of by joists are (2) 2x10, one is a (2) and (2) corner, so notch will be cutting a bit one that one.
long short, pretty much like the second picture.
I'm also surprised at the minimal feedback.
Old 06-05-2013, 05:19 PM   #4
what do you mean support posts in the middle of the span?
I didn't realize you we're going over a deck.
So did we...our deck is three feet above ground.
we have 2 x 6 posts ( 4 of them) holding up
our 14 x 20 foot pergola.
The 2 x 6 posts are cemented in the ground
and also bolted to our joists under the top decking.
We built this deck in 1973 and the Pergola we
built in 1976.
Old 06-05-2013, 05:30 PM   #5
I took this yesterday to email our friend who supplied us with
the new vinyl coated polyester fabric to make the new sun screen.
pergola drawing questions/span/doubler's??-image.jpg
Old 06-05-2013, 05:32 PM   #6
having trouble posting pic's
Old 06-05-2013, 06:59 PM   #7
Here's more pic's from 2003
This is from 2006 attached to the house.
I'll look for a pic of the bottom with the uprights attached to the
deck.
Old 06-05-2013, 07:36 PM   #8
This is the best one I could find showing the attachment of the
uprights.
The deck was built in 1973...and the Pergola in 1976
The stair rail (before staining) was added in July 2011 for safety.
pergola drawing questions/span/doubler's??-005.jpg-rev-2.jpg
Old 06-06-2013, 04:18 PM   #9
Looks like a cozy place, I love that space. And wow elaborate way to attach to house.
The span I was talking about was the "beam" at the outside of the deck/pergola running parallel to the house, it had a 12ft span I was concerned with. which I'm just going to add another 6x6 in the middle where my guard post will be anyway.
Now I am wondering if I should be "notching" my posts to sit flush with the deck. I though it would be better to have the deck rest on the 6x6's notched and bolted then continue through the deck to serve as guard posts and also my pergola posts.
I thought this was what I should do. Now I'm questioning what's best?
Old 06-06-2013, 06:31 PM   #10
I have the head guy looking at your post as we speak.
to help you out. In the mean time here is the pitch.
2003...Since this we took the rail down on the bottom deck.
Old 06-06-2013, 08:18 PM   #11
cs, We're having trouble understanding what you mean about notching?
Our beams are 14' long (I cropped the pics from yesterday)
each 14' beam is notched on both sides to fit over 20' beams that
run parallel to the house...the notch is only about 3/4" deep...it looks deeper
because in between each section he placed a 2" x 2" stifner between
each beam ( the beams are 2 foot apart ) I hope this is clear.
note that the notch looks deeper than 3/4" ...cutting it only 3/4"
keeps it strong.
Old 06-07-2013, 05:36 AM   #12
close up of notch and 2" stiffener.
Old 06-09-2013, 02:39 PM   #13
that's a pretty neat way to use that notch with using that "stiffener" board. Looks good.
I have a new post it drifted a bit from just the pergola so I made a new topic.
My deck plans (drawing) input please.
I'm trying to get the overall plans figured out for both deck and pergola support so I get it to work together, once that is done I will be looking above head to get the pergola itself figured out.
I am interested how you attached those unique brackets to that soffit fascia area and be strong enough. I might be able to use something in that area but never knew it would be an option. you see I'm limited on space
Old 06-09-2013, 11:47 PM   #14
check your mail.
Old 07-14-2016, 11:19 AM   #15
Rewards Points: 2
Re: pergola drawing questions/span/doubler's??
Hello I was wondering if you had the plans for the pieces you created, for attaching the pergola to a house with gutters.
Danny79 is offline   Reply With Quote
Rinnai combination drawing, HELP ChrisDIY Plumbing 18 08-24-2011 08:53 PM
Pergola over existing deck cpfullback Building & Construction 0 08-04-2011 12:36 PM
Pergola on Elevated Deck stubits Building & Construction 0 06-19-2010 09:48 AM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 09:30 PM
plumbing permit drawing sprengle1 Plumbing 1 01-21-2006 05:36 PM
