Pergola Design Help - Carpentry - DIY Chatroom Home Improvement Forum
Old 05-21-2010, 10:03 PM   #1
Post
Pergola design help
I'm having a 14' x 11' pergola built in the back yard. The posts and beams are 6x6. The rafters are 2x6. I think it's a pretty simple design but I am concerned about the 14' span on the 6x6 beams. I fear that without a post in the middle of that 14' span there will be dipping and warping. Can you recommend a method to engineer the beams so they don't dip without putting a post in between?
Please see the link below for design specs:
http://pergola15.shutterfly.com/pictures
lalaland is offline   Reply With Quote
Old 05-22-2010, 02:21 AM   #2
For some heavy reading you could look at:
http://www.awc.org/pdf/wsdd/c2b.pdf
and
http://www.awc.org/pdf/wsdd/c2a.pdf
Suffice to say, weight will be on the beam relatively uniformly, the table at the end of the first link only goes up to 13' spans. Depending on the Fb value of your wood choice (basically PSI it can support before bending) it should support anywhere from 1279 at the low end to 2844 at the high end, which sounds like plenty unless this is really heavy wood.
I'd be a little bit more concerned about how you plan on attaching the beams to the post as the diagrams don't show it.
oops, weight's in above post are in pounds
Sorry, I'm finding the above articles very interesting. Just so you know you can get more support strength from a 2X12 beam that a 6X6 and it might be cheaper too, course it may not look as nice.
Troglodyte is offline   Reply With Quote
Old 05-22-2010, 11:06 AM   #3
Question
Re: Pergola Design Help
and
Thanks Trolodyte. I'm afraid this is all Greek to me. Actually the span on the beams is only 13' because they will be attached on the face of the posts rather than across the top (follow the link in my original post for all the specs). What are your concerns about this method?
Old 05-22-2010, 12:23 PM   #4
Old School
Willie T's Avatar
BTW, it would still be a 13' span, even if the beams were sitting on top.
Franšois Duc de La Rochefoucauld
Willie T
Tags
beams , pergola , posts , span
Ceiling Fan Installation for Pergola stubits Electrical 19 04-05-2010 12:36 PM
Attached Pergola stubits Building & Construction 5 08-01-2009 01:07 PM
Patio Cover Design Questions MrBill Building & Construction 3 06-09-2009 10:34 PM
Building a Large Pergola CCE1876 Building & Construction 1 04-28-2009 02:19 PM
Pergola - paint or stain - then maintenance woodsglen Painting 2 07-15-2008 08:30 PM
