Pergola - Attaching Rafters To Beams? - Carpentry - DIY Chatroom Home Improvement Forum
Old 03-11-2009, 10:20 PM   #1
Rewards Points: 55
Pergola - Attaching rafters to beams?
I am just planning my pergola. While looking at photos of pergolas I see many in which I cannot ascertain how the rafters are attached to the beams.
They are not notched and there are no joist hangers evident.
Here is a link to one example of what I am talking about - how is the rafter attached? It looks like it's just sitting up there.
http://www.hgtv.com/designers-portfo...311/index.html
[IMG]file:///C:/DOCUME%7E1/DEFAUL%7E1.DEF/LOCALS%7E1/Temp/moz-screenshot.jpg[/IMG]
Italgrl is offline   Reply With Quote
Old 03-11-2009, 10:42 PM   #2
Rewards Points: 150
Send a message via AIM to Bocolo
It looks like they are bolted from the top. I may be wrong but they are definitely not just sitting there.
One Pound of Knowledge Requires Ten Pounds of Common Sense In Order To Be Useful
Bocolo is offline   Reply With Quote
Old 03-12-2009, 12:30 AM   #3
Rewards Points: 1,016
Lag bolts or drilled all the way though and use threaded rod - counter sink to hide.
Here's how I did my overhead - the beams that support the rafters are above rather than below the rafter - this was my solution to keep the beams out of the line of sight with a low "ceiling" height situation.
http://www.webjeepers.com/homestead.html
Old 03-12-2009, 12:59 AM   #4
Love for Construction
<*(((><'s Avatar
I framed a couple pergolas, when our framer was behind and we used 6" SDS screws from the top, countersunk and then filled with caulking and painted to protect from collecting water.
<*(((>< is offline   Reply With Quote
Old 03-12-2009, 09:28 AM   #5
Registered User
Termite's Avatar
That's what I'd do. SDS (or similar) screws can be bought from McFeeley's online and are also made by Simpson. You probably won't find them at the average hardware store. Fastenal would probably have them if they have a store in your city.
Old 03-12-2009, 09:48 AM   #6
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
My preference would be Fastenmaster Timberlock or Headlock; stonger and thiner. I'm impressed with all the Fastenmaster products.
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 03-12-2009, 10:07 PM   #7
Carpenter
DecksEtc's Avatar
This design has the beams toe screwed into the top of the posts they are sitting on. The curved knee braces are critical in this design.
Pergola - Attaching rafters to beams?-pergola-1-web.jpg   Pergola - Attaching rafters to beams?-pergola-2-web.jpg
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 03-13-2009, 08:10 AM   #8
If you don't want to drill lag through, you could toenail using pocket holes - with a kreg jig. I would toenail from both sides. And, you would need to fill the holes so you wouldn't see them - wouldn't be a problem with a painted thing as in the linked picture but would be more of an issue with teh one immediately before this reply...
plunkinberry is offline   Reply With Quote
Old 03-13-2009, 07:35 PM   #9
With a pergola you always want to drill or countersink so that the water drains out. Screwing from the top or drilling from the top is not recommended unless you plug and seal with an epoxy. Always let the water escape so you don't get rot. Holes drilled from underneath the beam and then lags or timberloks work great. Plugs then conceal the holes.
Josh Jaros Remodeling in The Woodlands, Texas www.jarosbros.com
jaros bros. is offline   Reply With Quote
Old 03-13-2009, 08:33 PM   #10
Carpenter
DecksEtc's Avatar
All the screw heads were plugged in the pics of the pergola I posted.
Terry
DECKS Etc.
GardenStructure.com
Attaching pergola to brick veneer house Mikedks Building & Construction 4 12-28-2008 01:01 PM
Attaching Rafters to existing roof truss' houstonbrama Building & Construction 7 08-21-2008 02:39 AM
attaching joists to ledger for pergola question soupdizzle Building & Construction 1 07-02-2008 11:32 PM
Inexpensive paintable pergola beams? dbosso Building & Construction 1 12-30-2007 10:14 PM
