Perfect Cut Crown - Carpentry - DIY Chatroom Home Improvement Forum
Old 11-03-2010, 11:59 PM   #1
Perfect Cut Crown
I just purchaced this crown moulding from the Home Depot. Has anyone used it or have any comments or suggestions about it.?.?.
LOUSY CARPENTER is offline   Reply With Quote
Old 11-04-2010, 12:56 AM   #2
jlhaslip's Avatar
Rewards Points: 384
What size is it?
What style of wood? or MDF? Veneered? Paint grade?
What spring angle?
Do you plan on coping the corners?
Do you have a compound mitre saw?
Ever done Crown before? Upside down and backwards works for me.
Originally Posted by Bud Cline View Post
Go ahead and apply for a variance, those guys at City Hall can use a good laugh.
jlhaslip is online now   Reply With Quote
The Following User Says Thank You to jlhaslip For This Useful Post:
BigJim (11-04-2010)
Old 11-04-2010, 07:05 AM   #3
I assume that is a brand name???? I have never paid attention to brand names on trim, so not sure what the difference is.
Old 11-04-2010, 10:14 AM   #4
Hey Lousy Carpenter,
I am Gregg from the Home Depot in Chicago. Basically the type of crown moulding you have has the design of the profile on both the front and back side, which makes it super easy to cut the angles with just a miter saw. Now all we need is for the trim to hang itself on the wall. I have done demonstrations of this product since it was introduced and I really like it. There is still a lot of skill involved in the install, such as, measuring, adjusting the angles to make a perfect fit, and accounting for unlevel ceilings, but the perfect cut really helps the process especially if it is your first time installing crown. Here are the instruction for the Perfect Crownhttp://www.homedepot.com/hdus/en_US/...rPad2-5-10.pdf . Hope the install goes well, if you have more questions about crown moulding let us know. –Gregg
gotogregg is offline   Reply With Quote
Old 11-04-2010, 01:33 PM   #5
Rewards Points: 150
Grinder a sanding disc work great if you are good with a grinder.
ianc435 is offline   Reply With Quote
General crown molding tips for rookies. speedster1 Carpentry 5 02-16-2010 08:18 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Crown Moulding Question lda130 Carpentry 2 11-21-2009 11:41 PM
Mixing differnet crown moldings moondog111 Carpentry 13 12-07-2008 10:40 PM
Crown Caulking Not Sure Carpentry 3 08-18-2006 10:40 PM
