Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-21-2009, 11:09 PM   #1
Jim Crockett
Patio Screens
My home has wooden frame patio screens. They have a routed groove at the center of each inside edge of the 1-1/8" frame and use spline. I have found replacing screens to be very difficult, especially at the corners, and have been searching for a way to convert them to removable panel screens. Five of the screens are nearly 5 feet tall, 4 of these are about 38" wide; another five are various sizes and shapes.
One thought I have had is to rout the wood between the groove and the inside face of the frame and install as in the olden days - staples and 1/4 round.
Any suggestions or hints on (1) replacing the screen/spline more easily or (2) converting the wood frames to accept the make-it-yourself vinyl or aluminum framing?
Thanks, Jim
jimc48 is offline   Reply With Quote
Old 05-22-2009, 07:19 AM   #2
Patio Screens
Screen-tite or Screeneze, Available at home stores, lumberyards.
Old 05-22-2009, 11:33 AM   #3
Old School
Willie T's Avatar
Patio Screens
ScreenEze, maybe. But you still have to use spline with Screen-Tite, don't you?
Willie T
Old 05-23-2009, 07:11 AM   #4
Patio Screens
You have to use spline with screetite, but once installed, the screen stays tight for a very long time. I have jobs I did years ago that are still tight. And replacing damages screens is easier. There seems to be fewer damge problems with birds flying into the screens, something my old screens had.
slumped patio fix ?? houser Building & Construction 5 03-18-2010 07:25 AM
Building deck over concrete patio stro77 Building & Construction 8 06-25-2009 05:21 PM
Need Patio Advice - Pictures Included kyassassin Landscaping & Lawn Care 45 05-14-2009 02:41 PM
Cement Patio Deteriorating..? DeepDish Building & Construction 6 05-09-2007 11:03 PM
New Patio & Weep Screed Woes DeepDish Building & Construction 3 12-03-2006 09:11 AM
