Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-24-2010, 02:24 PM   #1
Question
Patio Beam Span-Size
I am building a detach garage with a 32' Long by 16' wide patio roof. I'd like to place 3 posts which would drive a 16 beam span. Was wondeing what size beams I would need. It is in S. Texas so no snow load. Rafters will be 2X8 Cedar. Patio roof will have bead board and 30 yr asphalt shingles. It appears weight on the posts will be minimal. Any idea of the size beam I will need for these spans? Most references that I've turne up have been for home roof beams.
JDAAMS is offline   Reply With Quote
strengthening an existing beam ericw1 Building & Construction 7 07-29-2009 06:44 PM
what kind & size floor joists needed to span 15 feet? redss Building & Construction 17 07-11-2009 06:02 PM
Patio Roof Beam Span slakfu Building & Construction 4 06-03-2009 11:45 PM
Cutting a beam flange devlin1k Building & Construction 17 02-13-2009 04:24 PM
Basement Beam and Columns..... shamrock33 Building & Construction 1 03-19-2008 06:03 PM
