Partition Wall Of Plumb 3/4" In 8 Feet, Help - Carpentry - DIY Chatroom Home Improvement Forum
Old 09-03-2010, 01:17 AM   #1
Rewards Points: 337
partition wall of plumb 3/4" in 8 feet, help
So I am in the middle of a kitchen re-mod and I am looking at the wall seperating the kitchen from dinning room, it has a 3" opening that's finished in drywall. I though something looked wierd so I put a 6.5 foot level on the wall and was just shocked? I had my drywall guy look at it and it appears the each side of the opening is opening toward the dinning roomat the bottom plate. I.e. there is a 3/4 gap at the bottom plate on the kitchen side and a 3/4" gap towards the header on the opposite side in the dinning room. Opening a can of worms to fix???
Drywall guy said cut the nails holding the bottom plate to the slab on each side of the door opening and knock the bottom plate on each side in towards the kitchen and re-bolt the bottom plate to the slab then re-do the drywall.
This is not a loadbearing wall, does this sound correct?
titan7 is offline   Reply With Quote
Old 09-03-2010, 09:02 AM   #2
Rewards Points: 6,652
Sounds like someone was not using a plumb bob & 4-6' level. Also standing at the farthest point away from the wall can tell you visually if out of plumb.
Old 09-03-2010, 09:46 AM   #3
Old School
Willie T's Avatar
No. Do not move either the top or the bottom UNTIL you determine (by comparative measuring) whether it is the top or the bottom that is out of line.
Willie T
Old 09-03-2010, 04:20 PM   #4
Rewards Points: 337
How would I do this comparitive measurement? I will post a photo but what I think is happening is the two bottom plates start to open up into the dinning room about 20 inches from the opening on each side. I think I placed a square in the corner and the wall is opening up at the bottom much more than the top. Am I missing anything?
Old 09-03-2010, 06:48 PM   #5
Plumb Bob as I mentioned before. If you have a bolt & some string, that will work. Hang the line from the ceiling by the wall, and it will tell you were it is out of plumb.
Old 09-03-2010, 08:12 PM   #6
Rewards Points: 18
Comparative measuring would be measuring at the ceiling and then the floor from your non-plumb wall to a plumb wall running parallel to it. Before moving the wall determine if it contains plumbing electrical or heating that might be damaged by moving the wall.
daveb1 is offline   Reply With Quote
Old 09-03-2010, 08:15 PM   #7
Rewards Points: 337
Pics
here are the photos with the plumb Bob.
The first picture is on the kitchen side. I am holding the string at the top of the finished drywall 8 feet off the floor. The second photo I am holding the string at the top of the door opening. If I hold the string at the top of the ceiling the string hits the wall. In photo 2 the tape measure is in the kitchen side.
And yes I can see the wall is out of plum, a stranger would not unless I pointed it out.
Old 09-03-2010, 10:56 PM   #8
First pic tells nothing, second still shows nothing. In order to see if out of plumb or not, you need to step back as stated before, then take the picture. That means getting a nice shot from the front or back facing the doorway as if you are walking through. That would show us how far out of plumb.
And when taking measurements, you measure at the top, the middle top, the bottom middle, then the top of the Plumb and figure out how far out of plumb. Now, if you can find one of the old timers that used to do this stuff back in the days, they could tell you without even pulling out the tape measure how far out of plumb the door way is.
Old 09-04-2010, 06:32 AM   #9
Rewards Points: 1,522
I'd only try to fix the lean if it bothers you enough to do all the work involved. Looks like carpet would be short to meet the wall if you kicked the base plate over 3/4" to resolve plumb.
bob22 is online now   Reply With Quote
Old 09-04-2010, 09:07 PM   #10
Rewards Points: 337
The flooring is all being replaced.
Lets Play The "How Much Stain Will I Need?" Game! Bgm94 Painting 5 02-11-2011 10:53 AM
partition wall big rob Carpentry 12 08-22-2010 06:47 PM
Running speaker wire from attic into exterior wall: Techniques? homerb Home Theater 1 07-15-2010 02:55 PM
Ceiling support for partition wall? hohadcr Carpentry 5 09-28-2009 09:38 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 08:23 PM
