Partition Separation - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-12-2009, 04:10 PM   #1
Partition separation
My house is 1974 vintage with fabricated trusses. I have partition separation due to improper truss installation. How can I fix this problem? Thanks.
mikalino is offline   Reply With Quote
Old 02-12-2009, 05:11 PM   #2
Not so new
12penny's Avatar
Rewards Points: 520
mik.....got a picture?
12penny is offline   Reply With Quote
The Following User Says Thank You to 12penny For This Useful Post:
mikalino (04-21-2010)
Old 02-12-2009, 05:48 PM   #3
Have no picture. I understand that prefab trusses are now installed with a slotted angle brace allowing the truss to move without pulling up the joist it is attached to with it. I have a 4' overhang front and back. What do these braces look like and where do you attach along truss?
Old 02-16-2009, 08:35 AM   #4
Extreme DIY'r Adk's, NY
Rewards Points: 272
You have truss uplift due to bowing of the bottom cord. This happens as the top cords shrink less or actually expand more than the bottom.
There are brackets that few contractors use that the ceiling sheetrock sits into. You dont fasten the ceiling rock for about 18" from the corners and it is held in this track then hooks to the wall not the truss. It allows float.
Does the seperation come and go in winter and summer (respectively) or is it always there?
If it is always there, then you could just patch it up.
If it comes and goes (more liekly) then at this point you could just add cove molding here and attach it only to the ceiling.
Trying to prevent it is nearly impossible. If you fasten the truss with some brace as you speak of... to the top plate of the wall it might just pull the top plate off the studs or raise the wall splitting it at the floor.
crecore is offline   Reply With Quote
The Following User Says Thank You to crecore For This Useful Post:
Old 02-16-2009, 08:38 AM   #5
Rewards Points: 272
Oh, and if at this age it is still coming and going with the seasons... better attic air flow may help to reduce the truss lift. I like ridge and soffit vent. Also make sure no moisture is trapped up there esp. in the insulation.
Adding a partition wall to a room with hardwood flooring Badfish740 Remodeling 4 12-29-2008 07:54 AM
build secure three sided partition kevinr Carpentry 2 08-01-2008 10:46 AM
Framing a partition wall on existing carpet and ceiling tile? eagle86 Building & Construction 3 07-23-2008 03:39 PM
I'm going to build a partition wall.. flyboylr45 Building & Construction 6 10-05-2007 09:56 PM
