Pantry Shelves...What To Use? - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-12-2012, 10:12 PM   #1
Rewards Points: 208
Pantry Shelves...What to Use?
i'm redoing a pantry with new shelving.
what type of shelves should i get? would those pre-finished white shelves at home depot be good?
Scully is offline   Reply With Quote
Old 02-12-2012, 10:23 PM   #2
Rewards Points: 13,994
If you do not mind them sagging when you put caned goods on them. There nothing but cheap partical board.
I like to use the wire shelving sold in Lowes and Home Depot, there strong and easy to install with simple tools, or laminated pine shelving sold in the lumber area at Lowes, that gets primed and painted with enamel paint, wire racks sold at Home Depot instead of shelving. There fully adjustable and super strong.
Old 02-12-2012, 10:27 PM   #3
Ironlight's Avatar
The wire shelving has a couple of advantages for pantries. They don't collect dust/rice/flour whatever, and are easy to clean, and they let light through so it's easier to see things and find things.
If you do end up using wood, get solid pine, don't make your shelves wider than 30" or they will sag.
Ironlight is offline   Reply With Quote
Old 02-12-2012, 10:30 PM   #4
Rewards Points: 208
solid pine shelves wider than 30" will sag too?
are the wire shelves more pricey than solid pine?
Old 02-12-2012, 10:34 PM   #5
Not a Noob or Boob
Go with the Shelf Genie system. But if you are on a budget you can use the HD shelves, just make sure they are secured like a box. Running a 1x2 piece of poplar upright will do the trick and reduce any sagging to nearly 0.
The problem with ventilated shelving is getting things to sit right. They have a tendency to tip between the wires.
Rob1975 is offline   Reply With Quote
Old 02-12-2012, 10:42 PM   #6
Shelves can be made any lenght you need as long as there's enough supports under them.
I like to keep panty shelving around 18" deep, any deeper and things get lost at the back.
Unless your trying to store items less then 1" wide there not going to tip with wire shelving.
If you know the exact lenghts you need the store can even cut them to length for you.
Old 02-12-2012, 10:48 PM   #7
Not a Noob or Boob
I am not going to argue about wiring shelving, other than I have installed and pulled out hundreds of feet of the stuff. Tall boxes even larger than 1" have a tendency to not be square on the bottom, such as cereal boxes, and will tip if not set in just right. I could give more examples, but you get the idea. Ventilated shelving is better suited for linen and bedroom closets. I have found that several people end up putting cardboard or 1/8" Masonite on top to help flatten the surface.
The Following User Says Thank You to Rob1975 For This Useful Post:
Jay 78 (02-13-2012)
Old 02-12-2012, 10:59 PM   #8
Agree to disagree. To bad you live so far away I need some more of it.
There are great for a linin closit for the air flow through them.
Old 02-12-2012, 11:00 PM   #9
Not a Noob or Boob
I have a brother in Richmond. We are visiting this summer, I can call you when we get in.
Old 02-12-2012, 11:04 PM   #10
Rewards Points: 208
Old 02-13-2012, 09:50 AM   #11
Rewards Points: 190
I recently pulled out sagging white vinyl particle board shelves in the pantry and went with red oak 3/4" thick. Zero sag and will last forever. Used Watco wipe on Danish Teak oil finish. Looks better than pine and not much cost difference.
zircon is offline   Reply With Quote
Old 02-13-2012, 09:53 AM   #12
must of the shelves we do are plywood rip down to what ever width you want and then we put a edge band of pine over the plywood edges, of course make sure you have enough support for the spand of the shelves pei canada
2443 is offline   Reply With Quote
Old 02-13-2012, 07:56 PM   #13
Go granite with a bull nose and plywood backing. Should not sag.
On the less expensive but attractive route 3/4" paint grade birch plywood with an iron on tape for the edge. Then you have a high quality shelf that you can either prime and paint or give it an oil sealer and clear finish for the wood look. A 3/4" x 2" stiffener does wonders to stop saging. Just set it on edge 3/4" back from the front face.
masterofall is offline   Reply With Quote
Revolving shelves pantry nicksteel Carpentry 16 05-23-2011 05:10 PM
Pantry Sliding Shelves nicksteel Carpentry 14 05-23-2011 05:07 PM
Cantilever shelves in bathroom pennshaq Remodeling 1 07-11-2010 08:26 PM
Help! Newcomer trying to install pantry shelves louriec Carpentry 4 06-09-2010 12:30 PM
Extending pantry shelves info@homeworkbydave.com Carpentry 6 10-24-2008 08:57 PM
