Paneling Over Stud Walls - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-24-2009, 11:12 AM   #1
Question
Paneling over Stud Walls
We want to put some sort of affordable wood paneling the bedrooms of our new home. (Yeah I know most people don't like paneling but it's a personal preference.) I would love to use REAL wood, but I don't know if we can afford it so we've looked at some printed panels. Most of these are on laminated on plywood or OSB or MDF and are not as thick as sheetrock. The electrical boxes have been installed so that they come out from the studs 1/2" or 5/8" (I haven't actually measured it but my plan had called for 1/2" wall covering.) If the paneling is less than 1/2" thick what are some options for dealing with the discrepency. I was also concerned that the wall would be flimsy and "give" if it is less than 1/2". Any suggestions? What kinds of paneling are best?
techinstructor is offline   Reply With Quote
Old 06-24-2009, 11:55 AM   #2
Remodeler
adpanko's Avatar
Rewards Points: 150
I think the best option would be to put up normal 1/2" drywall, don't worry about finishing the joints with tape and spackle, and then put the paneling over that. Paneling is likely only about 1/4". So yes, your outlet boxes would stick out, which isn't allowed. But you can buy an outlet box extender for a dollar or two if you have the opposite problem. 1/2" drywall is only about $6 for a 4'x8' sheet, so it is cheap. Plus, if you only put up 1/4" paneling straight onto the studs, the paneling will be flimsy like you said. But drywall behind it will firm it all up real nice, and the drywall will add insulation and sound dampening qualities that the panels won't. And then you can just get the outlet box extenders since you're outlet boxes will probably be set too far back if you use 1/2" dryall with paneling on top of that. Putting up the drywall first will add some time and about $50 to the job (depending on the size of the room), but it is a much better way to go about it.
As for what kind of paneling to get, I have no idea. That is all personal preference.
adpanko is offline   Reply With Quote
Old 06-24-2009, 11:09 PM   #3
Registered User
Rewards Points: 4,936
Ask your local Building Department Inspector. Some areas require 1/2" wallboard behind paneling that is less than 1/4" thick. http://nrha.web-pros.com/How-To/floo...g/paneling.htm Be safe, G
Old 06-24-2009, 11:18 PM   #4
Yeah, paneling alone will be very flimsy
I've seen it done - basement
Someone stumbled, put there hand out - fell against the wall
Their hand broke right thru the paneling
Old 06-26-2009, 02:46 PM   #5
Drywall contractor
Rewards Points: 1,070
Use 1/4" drywall for a backer and your boxes should be fine. HD and Lowes both sell it in this area. If not where you are, look for a drywall supply. Makes for a solid job, especially if you glue and nail both layers....
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
Old 06-30-2009, 06:39 PM   #6
Fireproofing is another benefit.
Kudos to the idea of the sheetrock. Don't forget that the sheetrock also gives you fireproofing benefits.
kd4ttc is offline   Reply With Quote
Looking for a step by step for framing basement walls/2x4's wrong direction/stairs??? xray328 Remodeling 27 06-19-2011 09:50 PM
uneven wood paneling joefromcal Carpentry 6 04-30-2009 10:50 PM
Will water lines freeze if placed behind insulated stud wall in basement? jpsmith Remodeling 22 03-05-2009 01:23 PM
Removal of paneling and drop ceiling margog85 Remodeling 14 07-25-2008 04:13 PM
