Overhang On Stairs Too Long? Solutions? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-16-2012, 08:32 PM   #16
Ole Wood Worker
BigJim's Avatar
Rewards Points: 118
Open riser stairs are not code here now days. If you have big feet you would know how easy it would be to hang your toe. With that much over hang you would only have 9 1/2 inches of useable tread of which 2 inches would be unsupported.
New members: Please consider adding your location to your profile.
He is no fool who gives what he cannot keep, to gain what he cannot lose.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 11-19-2012, 10:20 AM   #17
Bad news - A friend that I called to help out broke the bottom step by stepping on the overhang.
Good news - I reinforced the steps over the weekend, bought a new stair tread from HD.
I took 1.25" thick trim and placed it under the overhang up against the riser. Screwed into the riser with 2.5" screws.
Here is the broken step with the support attached under it. (I did the support then removed the old tread)
Here it is with paint started. Couldn't find oil based anywhere so I used acrylic latex with urethane additive. Doesn't go on nearly as well as oil but I'm in a time crunch.
underwhere is offline   Reply With Quote
Water leaking down outside concrete basement stairs handlethis Building & Construction 3 08-06-2010 04:49 PM
anchoring concrete stairs to the house amakarevic Building & Construction 2 06-14-2010 04:25 PM
Removing wall under stairs Lankston Building & Construction 3 06-10-2008 08:50 AM
Concrete stairs jmat1980 Building & Construction 2 04-19-2008 12:45 AM
Prefab or custom stairs? brokie General DIY Discussions 1 01-21-2008 08:11 PM
