#1 |
Overhang on stairs too long? Solutions?
I just bought a new house and had hardwood floors put in.
The existing stairs were already red oak so my floor guy re-stained them but as soon as he saw them said that the stairs were not to code...that the overhang was way too long. At first I thought since the house has been there for 30 years it wasn't a problem but after walking up and down them I realize that some of the overhang is flexing and fully capable of snapping off if someone fat was walking on the edges. Strange thing: the overhang is different on different steps. Suggestions? What are good options to support the steps? Here is what I've come up with so far: 1. Using some sort of trim and nailing it to the riser. As thick as possible. Maybe even some 1"x1" square pieces of wood. I'm not sure how effective this will be. 2. cutting pieces the exact shape of the existing riser and screwing them together...essentially doubling up on the riser. The downside of this would be shortened tread length. 3. Cutting pieces to screw into the riser but in the shape of an arch...essentially creating some support but hopefully not decreasing the tread where people are using it the most (in the center).
#2 |
Mod
How deep are the treads now?
A Picture Is Worth A Thousand Words Especially In The DIY Chatroom -NEW MEMBERS-
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. |
#3 |
Stairguy
Is the overhang the same on the returned ends?
#4 |
Overhang on stairs too long? Solutions? |
#5 |
what is hte rise of each step? are they all the same?
You may be able to add a piece to the risers to make them come out further. Would need new cove moulding (or flat moulding) on the sides and maybe the front. Could have the new risers stick out say 3/4" or 1/2" or whatever looks good and round the edge. |
#6 |
Mod
I see no way to make what's there "code compliant". A 11 1/2" tread with a 2 1/4" nosing only leaves 9 1/4" nose to nose (10" min. for code in most areas).
Adding something to the riser would would be the only way to add more support other than removing all of the treads and cutting an inch off the back. 3/4" - 1 1/4" overhang is code for the nosing.
Please include your basic location in your profile. Some of the answers given are specific to a Region or State. Last edited by kwikfishron; 11-13-2012 at 11:43 AM. |
#7 |
Thinking outside the box, why not remove the cove moulding you have now and install something like this instead.
http://www.archmillwork.com/home/am3...7/arc_108.html By gluing and using trim head screws to attach it, it would add the support needed but not effect the tread depth. |
| The Following User Says Thank You to joecaption For This Useful Post: | GBrackins (11-13-2012) |
#8 |
that was my thoughts as well Joe. Since the OP has a safety concern about the nosing by all means they should fix it.
I would like to address a comment that was made however in regards to code compliance. Sometimes people think an old home has to be brought up to code which is not always the case. who says your stairs are not compliant? from Chapter 1 of the 2009 International Residential Code (your code may differ) R102.7 Existing structures. The legal occupancy of any structure existing on the date of adoption of this code shall be permitted to continue without change, except as is specifically covered in this code, the International Property Maintenance Code or the International Fire Code, or as is deemed necessary by the building official for the general safety and welfare of the occupants and the public. Stairs are not one of the issues specifically covered ... but by all means fix that which is unsafe. you would need to verify stair requirements with your building official. A lot of states/local jurisdictions have modified the IRC requirements to allow different riser and thread measurements, i.e., the IRC requires a maximum 7-1/2" riser height and minimum 10" tread depth. Massachusetts has modified to allow 8-1/4" maximum riser height and 9" minimum tread depth.
Gary "You get what you pay for, and sometimes free costs more!" |
#9 |
STAFF
The reason the stairs are out of code is they could cause someone to hang their toe and fall.
Even with that type of support trim it is still a tripper. Also on the descent, as they are now, there is only 7 1/2 inches of actual supported tread.
New members: Please consider adding your location to your profile, it helps other members to give more accurate answers to your questions. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. Jim |
| The Following User Says Thank You to BigJim For This Useful Post: | mae-ling (11-13-2012) |
#10 |
Here treads do not need to be 10" that is just optimum.
Here we can go from about 9.25 to 13" |
#11 |
journeyman carpenter
kwik and big jim are both right. the other issue is that with such a large overhang the glue joint in the tread itself can fail causing the tread to crack and snap off. ive seen this on old homes.. not a fun fix.. requires injecting glue , long trim screws and pocket hole screws to keep it clean looking
#12 |
Pack out the risers with some 5/4
If my advise helped you hit "Thanks" To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
#13 |
Thanks for all the responses guys.
I had considered adding onto the riser. Didn't even consider it a tripping hazard but I get that now. Just not sure what to do about it. I may take a "trip" down to Home Depot to see what kind of thick trim they have. That may end up being my solution. I need this fixed fast before family comes for Thanksgiving. |
#14 |
STAFF
If these were my stairs I would buy 1Xwhatever it takes for adding a new riser in front of the existing one, space the riser out so you have the correct over hang, glue everywhere wood touches wood.
On the outside edge I would install stair brackets like the picture here, to hide the raw edge of the newly installed riser. You would have to buy and install new scotia mold as the existing would be too short by installing the stair brackets and riser. JMHO
| The Following 2 Users Say Thank You to BigJim For This Useful Post: | hand drive (11-13-2012), mae-ling (11-13-2012) |
#15 |
I don't understand the concern about tripping because of the extended nosing?
People manage on stairs with an open riser, without falling on their face. Support under the nosing is all that is required! |
| Display Modes | |
| Water leaking down outside concrete basement stairs | handlethis | Building & Construction | 3 | 08-06-2010 04:49 PM |
| anchoring concrete stairs to the house | amakarevic | Building & Construction | 2 | 06-14-2010 04:25 PM |
| Removing wall under stairs | Lankston | Building & Construction | 3 | 06-10-2008 08:50 AM |
| Concrete stairs | jmat1980 | Building & Construction | 2 | 04-19-2008 12:45 AM |
| Prefab or custom stairs? | brokie | General Discussion | 1 | 01-21-2008 08:11 PM |
