Over Laying Old Floor - Carpentry - DIY Chatroom Home Improvement Forum
Old 02-03-2013, 11:29 PM   #1
Question
over laying old floor
i need help i bought a older trailer in a trailer park and one room has a soft floor in spots and i dont know if i can lay 1/4 osb over it and be ok any help ?
snowman21385 is offline   Reply With Quote
Old 02-03-2013, 11:33 PM   #2
Rewards Points: 13,296
You could but it will do 0 good.
Which room is it the bathroom?
Lots of mobile homes used nothing but partical board on the floors.
Gets wet one time and it turns to oat meal.
To fix it you would have to cut it out and replace with a new subfloor.
Old 02-03-2013, 11:50 PM   #3
It's n the bed room where the hot water heater is and the spot is maybe 2'x1' and idk if there r more so was thinking about overe laying whole floor
Old 02-04-2013, 12:01 AM   #4
Not a great plan to just lay new wood over rotten wood.
Old 02-04-2013, 12:46 AM   #5
It's not like all wet n rotten just soft
Old 02-04-2013, 07:08 AM   #6
Rewards Points: 1,294
It is soft because it was wet at one time and now id rotten. I will repeat what Joe said.
"Not a great plan to just lay new wood over rotten wood."
Cut out the bad spots and repair them first, then you can overlay. 1/4" over a weak spot wont give you any support anyway.
danpik is offline   Reply With Quote
Old 02-04-2013, 07:40 AM   #7
Ok Ty
Old 02-04-2013, 08:26 AM   #8
Ok Ty
So fix bad spots and put 1/2 over will that b ok
Old 02-04-2013, 08:57 AM   #9
Why would you go over it with 1/2, if the weak spots been fix?
What on there for flooring now, and what's the plans for the new flooring?
laying laminate floor without using beads and skirting board is in and to the floor phil portman Carpentry 2 08-03-2011 09:36 PM
Laying down laminate flooring on a concrete floor Joey_1984 Flooring 10 10-04-2009 09:42 PM
Carpet in the basement Packer Backer Flooring 16 11-04-2008 12:19 AM
Laying "new" wood floor next to sloping old floor troyce1 Flooring 25 10-16-2008 02:34 PM
does the floor really need to be level before laying tiles? KUIPORNG Flooring 29 11-04-2006 12:56 AM
