Outside Stairs (deck) - Carpentry - Page 4 - DIY Chatroom Home Improvement Forum
Old 05-13-2009, 05:19 AM   #46
Rewards Points: 5,336
Originally Posted by analogmusicman View Post
I kinda had an idea of what they might be. now the important question:
my frost line here in colo. springs is 25 in. down. so I dig a hole how deep? does the top of the concrete have to be below 25 in. ? this will be a pretty deep hole!
tnx,
Are you sure 25" is correct? On Long Island, NY it's 36"
Ron
Old 05-13-2009, 02:04 PM   #47
analogmusicman's Avatar
Rewards Points: 560
pulling the hangers off left holes in the joist they were attached to. I want THESE to be attached well. is it ok tp put screws in there and what size? (stainless?)
tnx,
analogmusicman is offline   Reply With Quote
Old 05-13-2009, 07:30 PM   #48
Rewards Points: 560
Ron
yeah, I've looked at several maps. the farther north you go,the deeper it gets,like northern Minn. is 5 feet!
tnx,
Old 05-14-2009, 02:42 PM   #49
Rewards Points: 560
HD and Lowes don't have the hanger I need,nobody does since whoever built the deck modified a standard joist hanger to do the job and a poor job it was. I'm seeing all sorts of things with this house which leads me to believe the building dept. must have been run by the previous owner's brother!
tnx,
Old 05-17-2009, 08:31 PM   #50
Rewards Points: 560
my daughter and son-in-law dug the hole where the sonotubes will go. the hole is about 3.5 feet deep. should I put the sonotubes in, backfill with dirt,tamp the dirt and THEN fill the tubes with concrete?
tnx,
Old 05-18-2009, 08:05 AM   #51
tnx,
I would also put about 6" of small angular stone into the sonotube, after back filling, and tamp it down.
Ron
Old 05-19-2009, 06:39 PM   #52
Rewards Points: 560
well,the hole is dug,the materials have been delivered and it's time to put concrete in the sonotubes. Lowe's sold me 8 bags of "redi-mix",4 per tube. I was gonna just mix it a bag at a time and shovel it in. is there a reason why I should rent a mixer?
tnx,
Old 05-19-2009, 07:56 PM   #53
I did one bag at a time in a wheel barrow
Made it easier to dump it in the tube
Old 05-20-2009, 03:24 PM   #54
Rewards Points: 560
about the 4x4 holder that sits on top of the concrete: is there a recommended height for it? the existing ones that hold up my deck have 2.5 in. of that 1 in. dia. round thingie showing.
tnx,
Old 05-21-2009, 04:48 AM   #55
tnx,
Try looking at the manufacturers site for specific hardware instructions.
Ron
Old 05-27-2009, 05:36 AM   #56
Carpenter
DecksEtc's Avatar
Ron
Sorry but that's a waste of time and money.
Completely unnecessary for footings.
BTW, the stone is recommended for the bottom of the hole for fence posts.
Terry
DECKS Etc.
GardenStructure.com
DecksEtc is offline   Reply With Quote
Old 05-27-2009, 03:06 PM   #57
Registered User
Rewards Points: 526
Sorry but that's a waste of time and money. Not according to the manufacturer.
Completely unnecessary for footings. Only if it's resting on undisturbed soil. Very hard to do, 3-5' down.
BTW, the stone is recommended for the bottom of the hole for fence posts. And anytime the concrete is not resting on undisturbed soil. To get a better (think more solid) base, not full of dirt clumps.
After you install a footing, the loads are transferred down to the earth. You want a good full contact. The tamped rock helps attain this when you are unable to clean the disturbed soil away to get a smooth base. Second choice would be tamped rock, last choice (the worst) is loose dirt still in the hole from the digging implement.
Sonotube's recommendations for footing use:
http://www.sonotube.com/products/tubebase_install.html See the whole idea, using it alone as a footing.
Be safe, G
Old 05-27-2009, 05:41 PM   #58
Old School
Willie T's Avatar
I thought 1M means ONE thousand
tnx,
As a carpenter, you are perfectly correct.
M= one thousand board feet. Always has. But this is how it is seen today (outside the lumber yard)
M [1] an informal abbreviation for million in expressions such as "$500M" for 500 million dollars or "Unemployment Reaches 4M" in a newspaper headline.
In binary contexts such as computer memory, M often represents 220 = 1 048 576
M [2] the Roman numeral 1000, sometimes used in symbols to indicate a thousand, as in Mcf, a traditional symbol for 1000 cubic feet.
Given the widespread use of M to mean one million, this older use of M to mean one thousand is very confusing and probably should be scrapped.
Willie T
Old 05-27-2009, 10:07 PM   #59
Carpenter
DecksEtc's Avatar
Be safe, G
Please show me where in the Building Code that it states that the above method is required?
I have NEVER once had a building dept./inspector tell me to put clear stone at the bottom of a deck footing, EVER.
Until this happens, I won't be wasting any time/money on dumping clear stone at the bottom of my footings.
All of my decks are plenty safe, thank you very much.
Terry
DECKS Etc.
GardenStructure.com
Old 05-27-2009, 10:12 PM   #60
I've always used a 4x4 post to tamp my holes down
But if it seems muddy I also toss some rock in & tamp again
I hit ledge in most holes at this house
Sometimes common sense is a step above code
avoiding slippery deck stairs rln17 Painting 2 09-12-2008 01:42 AM
Deck Stairs bajaboy1 Building & Construction 35 06-13-2008 04:40 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 03:37 PM
Deck stairs gmjosey Carpentry 1 06-08-2006 06:34 AM
