Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 05-09-2009, 08:22 PM   #31
outside stairs (deck)
Originally Posted by Scuba_Dave View Post
Yes - I used simpson L brackets under the stairs - I think they were 3" wide - so not a normal L bracket
I had cement block on the stairs & had my wife sit on them
Then I screwed each one in - starting at the lowest step
I am going to try it soon as I can. thanks
texas115115 is offline   Reply With Quote
Old 05-10-2009, 04:39 PM   #32
analogmusicman's Avatar
hmmm...Texas, you and the Scuba just might be talking about different things :-)
anyways, what's better,ring shank or smooth nails?
tnx,
analogmusicman is offline   Reply With Quote
Old 05-10-2009, 07:04 PM   #33
Ring. the rings hold better as the wood moves. The rings are very small though. Thats why screws are better. Also if repairs are ever needed much easier to remove screws than ring shanh nails. Good luck how ever you go. Have fun
Old 05-10-2009, 10:22 PM   #34
does this look like a decent deal?
304 STAINLESS STEEL 3" x .120 RING STRIP NAILS 21° PLASTIC 1M BOX
Price: $89.95
Full Round Head, Ring shank
1000 count, 304 Grade Stainless
FREE SHIPPING IN THE U.S.
I wonder,is .120 sufficient for stairs? the next size up is .131 for alot more.
tnx,ken
Old 05-10-2009, 11:33 PM   #35
Price: $89.95
tnx,ken
You get 2000 nails in a box right, thats $0.044975 per nail.
Old 05-11-2009, 05:39 PM   #36
I thought 1M means ONE thousand
tnx,
Old 05-11-2009, 08:21 PM   #37
so,what's a "sonotube" anyway? and how would I use them to put a couple posts into the ground to support the stairs?
tnx,
Old 05-11-2009, 08:40 PM   #38
tnx,
I did not see that. I get boxes of nails at 2000 per box and assumied that would hold ture to the ones you found. Still not too bad, but I am cheep so I wopuld look some more unless I had been looking a long time.
Old 05-11-2009, 10:02 PM   #39
whew! thought I was gonna hafta divide everything you said by 2
Old 05-11-2009, 11:21 PM   #40
Xtreme DIY'r
Sono tube, and with post bracket
Old 05-12-2009, 12:21 AM   #41
I kinda had an idea of what they might be. now the important question:
my frost line here in colo. springs is 25 in. down. so I dig a hole how deep? does the top of the concrete have to be below 25 in. ? this will be a pretty deep hole!
tnx,
Old 05-12-2009, 09:45 PM   #42
took down a couple stringers today. looks like whoever built the stairs used roofing nails to secure the hangers. those nails came right out. scary to think that those stairs were held up all these years by some roofing nails that came right out. good thing none of us in the family are heavyweights or that we never had anything real heavy brought into the house via those stairs! (like a fridge)
tnx,ken
Old 05-12-2009, 10:00 PM   #43
Xtreme DIY'r
tnx,
No - the top of the concrete is above ground level
The bottom must be below the frost line
The bottom dirt/rockmust be tamped down hard before the concrete is poured
Old 05-12-2009, 10:41 PM   #44
whew...thought I was gonna hafta dig down to China
the hangers that were used to hold the stringers up (see my previous post) look like regular joist hangers EXCEPT the top part is angled to accomodate the angle of the stringer as it goes down to the ground. anyone know if HD or Lowes sells these?
tnx,
Old 05-12-2009, 11:01 PM   #45
Xtreme DIY'r
Yes - HD has the angled joist hangers
Lowes should have them too
avoiding slippery deck stairs rln17 Painting 2 09-12-2008 02:42 AM
Deck Stairs bajaboy1 Building & Construction 35 06-13-2008 05:40 AM
The Bioswale, french drain, deck, drainage dilemma (long) seabright_sc Building & Construction 2 01-05-2008 04:37 PM
Deck stairs gmjosey Carpentry 1 06-08-2006 07:34 AM
