Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 08-05-2009, 04:35 PM   #1
Outdoor stairs need to be fixed...
I have some stairs that lead to a 2nd floor coach house above the garage. A problem has cropped up where the part of the stairs that attache to the outer wall of the the coach house is starting to rot. Not the stairs themselves as much as what the stairs rest on, on the side that is the coach house wall (there is a name for this component I am sure, I just don't know it).
From the underside I can see that untreated wood was used, and it was installed first before it was painted, so the side that is against the coach house wall doesn't even have paint on it. There are parts that I can push on and it is even soft.
Besides the wood not being protected or treated, the problem is magnified by the problem that the stairs slant to the coach house, meaning that when it rains, water just collects against the stair and the coach house. The rest of the stair components are in reasonable condition.
How difficult would it be to pop off the stairs, and then replace that piece of wood that attaches to the coachhouse? I think you can buy these zig zagged pieces of wood for stairs, can't you? I am slowly getting more and more handy with carpentry (out of financial necessity), but wondering if this is something difficult, and I should just get a carpenter, or take a shot myself. If people think it would help, I can upload some pictures...
2031pratt is offline   Reply With Quote
Old 08-05-2009, 05:01 PM   #2
the "zig zag" part is called the stringer and you can buy one or cut your own...just trace the old one......i don't know how many stepsthere are....but usually reaplacing rotten wood is pretty simple yet sometimes time consuming......when you replace rotten wood remember if there is anything left of the wood at all you have a template to work from.,... i am just thinking out loud here by saying...be sure that the rotten wood is not part of the structure of the "coach house" if so you may need some professional advise or just some pictures posted on here,..
ropers is offline   Reply With Quote
Old 08-06-2009, 01:06 AM   #3
its not that difficult of a job but you need to have basic carpentry skills. just take off the old treads, carefully remove the stringer you want to replace (the zig zag thing), and as stated above trace it. while the stringer is off, look at the side of the house, where the stinger was attached, and if theres any rot, remove it, and replace it. the key here is to make sure what you are nailing the new stringer to is a solid piece of wood, not soft and rotted out wood. otherwise it will sag down again and you'll have the same problem in a few years. hope this helps, and good luck.
hammertime09 is offline   Reply With Quote
More On This Topic
Hi this is Jon on behalf of Expert Village in this video clip I will show you how to remove your side trim boards. On this side we need to remove our gutter first before we can have access to our trim board. You need to unscrew where you gutter... Read More »
On behalf of Expert Village my name is Gale Stolove with Wholly Macro in Fort Lauderdale, Florida. Today we are going to talk about a day and the life of macrobiotics lifestyle. So I happen to live in a two story house which is not a bad thing I get alot... Read More »
We are going to put the roof on and we are going to hinge it so we can put the feed inside of it so we will make the roof come out. If you have a piece of wood that is a little bit wider than this it's kind of nice to use. It just happens that I have a... Read More »
It’s important for every home owner to familiarize themselves with the exterior of their house. A lot of times people don’t check on what’s going on outside their house. Especially on the side that they rarely see - until there’s... Read More »
It should come as no surprise to anyone who has read about Teddy Roosevelt and his life and personality that his home, "Sagamore Hill," is equal parts country manor, hunting lodge and boys clubhouse. Roosevelt and his second wife, Edith Carow, raised six... Read More »
Skylights? Anyone Ever Mix Venting Type with Fixed in same room? nomad943 Roofing 1 06-25-2009 11:12 PM
Reasons for big diff in fixed price bid prices tomseeley Roofing 4 06-11-2009 07:45 PM
Things break down in my house. Need help to get them fixed the right way! Curious123 General Discussion 10 04-14-2009 10:34 AM
Leaking fixed skylight mt232 Building & Construction 5 11-24-2007 12:12 AM
TXV or fixed cjett HVAC 1 09-29-2007 05:38 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
