Go Back   DIY Chatroom - DIY Home Improvement Forum > Home Improvement > Carpentry
Old 11-10-2012, 04:56 AM   #1
Question
Outdoor plants shelf - repair or remove?
Hi we have a small backyard and there are some plants stand/shelf (outdoor) right next to the lawn. However, over the past few years the wood was rotten and it became a home for lots of bugs (spider, black bugs, etc.)..
Here are some photos:
1. Would it worth to repair it? How? With wood hardener??
2. Since it has became the home of lots of insects, would it be wise to just get rid of it?? If I don't remove it would it cause more damages later (e.g. attract termite?
Thanks!
ohman is offline   Reply With Quote
Old 11-10-2012, 08:18 AM   #2
sdsester's Avatar
Am I looking at a screen porch with some repurosed shelves that were once indoor? They do not look like typical redwood or even treated exterior pot shelving? They are not laminated particle board or something are they?
Anyhow, I guess you could use expoxy liquid wood fillers followed by expoxy paste to repair the shelves. I used Abatron products but ConservEpoxy products are great too. The expoxy will cure harder than the wood ever was but the stuff is not cheap and whether it is worth it depends on how badly the shelves are rotted. I cannot really tell from the photo. If they are made of material that was never intended to be outside, I think I would just get rid of them and start over.
http://www.abatron.com/buildingandre....html?vmcchk=1
http://conservepoxy.com/mm5/merchant.mvc?Screen=PLST
Basic shelving is among the easiest things to build (or have built) so I think you will find it easier to start over with some nice redwood or treated material. Do build with better attention to drainage. You probably do not want a bottom shelf so close to the ground with real garden shelving (again I suspect your current shelves were repurposed from an interior use?).
Bugs should not be attracted to shelving any more than anything else but of course they like hiding in dark corners and some where organic matter like potting soil builds up. Spiders feed on other bugs. With shelves better suited to being in an outside environment and with drainage built in you should be able to hose them off to keep bugs from nesting.
Whether you just get rid of them and do not rebuild is up to you. You live in a climate where I think have shelves for potted plants is nice. I lived in San Jose and was able to grow many varieties of orchids outside. In San Francisco, 45 minutes away but on the Pacific for all intents and purposes, and even more directly influenced by the ocean and fog, you can even grow more and have a wonderful hybrid orchid nursery near you. You can also grow lots of what most of us consider houseplants on protected patios. Having a place to put different sized potted plants is nice I think? So long as you watch for insects bringing them indoors, houseplants really benefit from an outdoor vacation.
sdsester is offline   Reply With Quote
The Following User Says Thank You to sdsester For This Useful Post:
ohman (11-11-2012)
Old 11-10-2012, 08:59 AM   #3
AHH, SPANS!!!
tear them out, re build with same design or similar or move them around and evaluate if they are worth saving and remount them raised up off the floor...
hand drive is offline   Reply With Quote
Old 11-11-2012, 12:10 AM   #4
Would spraying some wood preservatives over the shelf help in some way?? I think sdsester was right that the shelf was probably re-purposed by previous house owner and the wood was not meant for outdoor use...thanks again!
Old 11-11-2012, 12:23 AM   #5
sdsester's Avatar
Nope.
Old 11-11-2012, 10:45 AM   #6
One of the pictures looks like re-purposed compressed wood painted over with outdoor paint to provide some outdoor protection. That only last for so long if you don't routinely repaint it.
I would throw it out and make a new one with something like Cedar Wood. If you want to keep the beauty, you can poly it, or apply weather resistant sealant. Its naturally weather resistant, takes a very long time to rot, and also repels most bugs. That is one of the reasons why people store clothing in Cedar closets.
dlam01 is offline   Reply With Quote
Retrofit ceramic tile corner shelf in shower jgibbs Tiling, ceramics, marble 4 06-07-2012 12:29 PM
Cost estimate on window/sheet rock repair marchvet Building & Construction 26 12-01-2011 12:02 AM
Fireplace/chimney repair options sankavarmuch Building & Construction 0 11-10-2011 09:42 AM
How to remove outlet from tiled wall, then patch drywall and retile? Jakobud Kitchen & Bath Remodeling 18 10-15-2011 05:05 PM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
