Outdoor Cabinet And Countertop - Carpentry - DIY Chatroom Home Improvement Forum
Old 06-02-2013, 10:05 PM   #1
castroball5
Outdoor cabinet and countertop
M planning on building a base cabinet out of non pt material out by my pool. The countertop will be tiled and It will be completely covered from the rain and will not be sitting directly on the concrete.
My ? is, will the non pt hold up ok?
Also, when constructing the top, is pt plywood needed? Do I need a wp membrane? Was thinking about slate tile... Good or bad choice?
castroball5 is offline   Reply With Quote
Old 06-03-2013, 09:00 PM   #2
Rewards Points: 960
You don't need pt lumber. There are various types of wood which hold up reasonably well outdoors and yours will be shielded from the elements.
I build my countertops indoors with a layer of 3/4" plywood over the 3/4" plywood cabinet tops, then a layer of 1/2" tilebacker. I like to use denshield. I grout with epoxy or urethane. I like to use a wood edge.
You may as well use a waterproof tilebacker, but you can use durock if you like.
The wood edging would be your demise outdoors if it were exposed to the sunlight and elements. In your case, however, I would build pretty much the same as if it were to be indoors.
I don't have much experience with slate, other than floors, and I'm not a big fan of it on floors. I'm sure it will be fine for your application. If you want to have something more durable, you can find a porcelain which mimics the look of slate.
cleveman is offline   Reply With Quote
Old 06-03-2013, 09:10 PM   #3
castroball5
Sounds good. Thanks Cleve.
Old 06-04-2013, 03:00 PM   #4
Rewards Points: 327
We built an outdoor bar/ serving counter on our deck Twelve or
thirteen years ago. We used cedar and a ceramic tile top. It is exposed
to the elements. It has held up well.
We cut slats for the sides
because it houses two small under the counter fridges, and we
wanted the air to circulate.
Btw, the edge of the top is cedar.
Two Knots is offline   Reply With Quote
Old 06-04-2013, 03:31 PM   #5
Rewards Points: 327
Just re-read your post. You said it will not be sitting directly on the cement? where will it be sitting?
This is ours, I know I'm a picture posting fool. We use these fridges
all year long.
this is from July 2011...we also have a cliff-rigged running water to it from
our hose.
Old 06-04-2013, 03:56 PM   #6
castroball5
What I meant was the cabinet itself will not be on the concrete. ( no wood touching concrete) I'm going to install metal legs to keep it off the ground about 2-3 inches
laminate countertop question photopeter Kitchen & Bath Remodeling 2 12-18-2011 02:32 PM
How to install countertop over washer and dryer R V Dunai Remodeling 13 08-21-2011 02:07 PM
How to remove cultured marble bathroom vanity countertop goshenplumber Building & Construction 4 03-04-2011 04:56 PM
receptable inside cabinet DIYGST Electrical 8 01-29-2010 07:05 PM
countertop installation - stove/oven issue diycarguy Building & Construction 12 05-04-2009 01:08 PM
