OSB Sheathing As Siding? - Carpentry - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-25-2011, 03:27 PM   #16
Rewards Points: 150
The shed is a 10x12.
CJIII is offline   Reply With Quote
Old 12-25-2011, 03:33 PM   #17
Rewards Points: 12,794
You keep picking siding that will needs painting and at some point is going to rot again. If you went with vinyl, no painting ever, no rot. Simple to put on. It's about $80.00 per square, that's 10'X10".
Old 12-25-2011, 04:00 PM   #18
Rewards Points: 150
What about this vinyl siding? http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053 How much sq ft in this one?
Old 12-25-2011, 04:13 PM   #19
That style siding comes in a 2 sq. box.
You would also need 4 outside corners, 5/8 J molding for around the door and windows, 1, piece of utility trim for under the windows, some 1-1/4 rooking nails and 4 starter strips.
Old 12-25-2011, 04:32 PM   #20
Rewards Points: 150
Ok thanks! So 2 squares will cover the shed?
Old 12-25-2011, 04:52 PM   #21
Your going to have to measure the lenght X the height of the area on all sides and add it up. Then divide by 100 to come up with a figure. At Home depot you can just buy some by the piece if it comes out to an odd number.
Old 12-25-2011, 09:07 PM   #22
Facilities Maintenance
Originally Posted by CJIII View Post
The LP Smartside looks like a good choice. What about T1-11 on top of the OSB?
You want to get rid of OSB completely. If the bottom edge has rotted, the rest will rot eventually with it. It's truly not worth hte money to burry "siding" that is potentially rotting in front of your face. It'll only serve to comprimise the structure.
Get rid of the OSB completely, put down some plywood over it, put tyvek over the plywood, and then put on whatever siding you want.
If you want vinyl, go with vinyl, you'll have to pressurewash it quite a bit throughout the year (or it looks like crap... Just saying) or you can use cement board, or you can use LP, or whatever you'd like.
It's your call. Either way, as long as you perform preventive maintenance (pressurewash, then recaulk, then paint every 3 years or 5 years) on the siding, they can all last you roughly 20-30 years without issue unless you failed to perform some preventive maintenance measures.
BigGuy01 is offline   Reply With Quote
Old 12-26-2011, 12:30 AM   #23
Rewards Points: 2,202
Is the shed right on or really close to the ground?
If you put vinyl siding over top you may still have a problem if the bottom edge of the OSB is left exposed.
mae-ling is offline   Reply With Quote
Old 12-26-2011, 09:10 AM   #24
Rewards Points: 150
Yes but I plan on jacking up the shed, to put it on blocks.
Old 12-26-2011, 10:34 AM   #25
In a little over my head
Rewards Points: 706
10x10 storage shed? Why not take off the OSB one or two sheets at a time and replace with T-111? Or, prepainted exterior paneling?
ratherbefishing is offline   Reply With Quote
Old 12-27-2011, 04:18 PM   #26
Tizzer's Avatar
Rewards Points: 452
If you're going to put this up on blocks, how were you planning to support the middle section. What is the shed floor? Joists or plywood or is there a floor?
Any pictures?
Tizzer is offline   Reply With Quote
Old 12-27-2011, 05:40 PM   #27
Rewards Points: 150
Its 2x6x10' Treated SYP space 24'' on center. Dont have any pictures at the momment but I can take some.
Gap between siding and sheathing & foundation? Wiscbldr Building & Construction 2 08-18-2011 07:56 AM
Sheathing with foamboard under siding billybarty Building & Construction 6 04-18-2008 01:46 PM
Siding: Cement Vs. Cedar Grumpy Remodeling 5 03-19-2005 02:07 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 1 03-19-2005 01:55 PM
Siding: Aluminum vs. Vinyl Grumpy Remodeling 0 04-18-2004 04:35 PM
